Identify this capacitor value
  • bclkjs
    • Aug 2016
    • 11
    • US
    Can anyone confirm whether this is a 3.3uf or 3uf capacitor?
    I've never seen a marking like this and the spacing of the 3's makes me wonder.
    http://imgur.com/a/0MQkv
    Thank you!
  • amirabueno
    • Jan 2014
    • 10
    • Philippines
    Re: Identify this capacitor value
    33uf
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • BlackBurn
      Help to identify a laptop mainboard SMD capacitor LA-9982P
      by BlackBurn
      I have an Dell Inspiron 15 3537 laptop mainboard (LA-9982P Rev. 3.0 (A02)) with a blown SMD capacitor as shown in the attached images. However, there is no printed specifications near the capacitor or a codename for the capacitor to identify the specification of the capacitor to replace it. I wonder how to identify the capacitor since the mainboard schematics are also useless as the capacitors are not named on the board. Any help would be highly appreciated.
      Thank You. Stay Safe.
      Chamara...
      11-27-2020, 08:30 AM
    • Agent24
      Dick Smith Q-1760 linear power supply filter capacitor question
      by Agent24
      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
      It has at least one problem.
      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
      I have already ordered a replacement potentiometer, so that's not an issue.
      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
      All are CapXon...
      10-21-2025, 05:39 PM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
    • chth96
      by chth96
      06-02-2024, 07:31 PM
