Reliable Sources for Nichicon MUSE Capacitors
  • jazzie366
    • May 2016
    • 304
    I can't seem to find a good place that sells Nichicon Muse, I have a Sunfire True Subwoofer MKII that I got at an auction for 50$. It had Jun Fu capacitors capping the whole thing. Two were bad, all the rest test as if they were brand new. I replaced the two bad ones with some Nichicon caps, but I want to do the job the rest of the way. Are there any good places for Nichicon MUSE capacitors?
    Also for those who don't know, the sub is a 2000$ subwoofer, I'm honestly shocked at the poor capacitors choice.
    Popcorn.
    • 31213
    Re: Reliable Sources for Nichicon MUSE Capacitors
    dont make the mistake of using audio caps in the power section.
    • mariushm
      • May 2011
      • 3799
      Digikey has a bunch of audio caps including some from the Muse series of Nichicon, also Silmic and tonerex from elna and others : https://www.digikey.com/short/3nzqp1
      Mouser also has audio capacitors from Nichicon and others, here's the Nichicon ones: http://www2.mouser.com/new/nichicon/...on-Audio-Caps/ and here's all of them : http://www2.mouser.com/Passive-Compo...5hqt?P=1yztuat
      • jazzie366
        • May 2016
        • 304
        All the caps are tone caps, such as 25v 470uF, 50v 1uF, etc. They're all the small caps on the board. The ones that bulged were power caps, they were replaced with some non-audio Nichicons. They'll last forever.
        Popcorn.
        • linuxguru
          • Apr 2005
          • 1564
          FWIW, I've measured the tan(delta) of various Nichicon MUSE series caps including the flagship KZ, and they were average - around 1 to 2% in most cases. Some generic low-ESR caps from other manufacturers, including Panasonic FM/FK, Rubycon YXA/YXG/ZL/ZLH and several others measure better, and in most cases sound about as good as MUSE. There are a few Nichicons that have exceptional linearity, including UD (SMD), but they're not generally stated by Nichicon as being made specifically for audio.
          For low capacitance values below about 3.3uF, I've switched to using film capacitors like Wima MKS2XL which are compact enough to fit in the same 5 mm pitch. For larger values, I use a mix of generic low ESRs from various manufacturers as stated above. For anything in the signal path, only film capacitors. For feedback DC blocking, the most linear cap of the required value, bypassed in some cases by a film cap.
          Parts Connexion has (or used to have) MUSE KZ in stock, and they're always authentic. The only MUSE series that was has been extremely useful for me is the subminiature (5 mm height) MUSE SW, which fits in various consumer boards with tight clearances, including sound cards, CD/DVD players and so on - YMMV. KZ is fairly bulky for its ratings, and can be tricky to fit in lots of consumer-electronic boards.
          • dragon3x
            by dragon3x
            power on.
            Here are some examples :
            switching supply area).
            than 6.3 V.)
            03-21-2025, 02:46 PM
          • DrewPhillips
            Capacitor Diarrhea - Nichicon PL Series
            by DrewPhillips
            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
            03-02-2025, 10:18 PM
          • xnRS
            Exactly same capacitors from NCC and Nichicon
            by xnRS
            I was searching some caps and found NCC KY and Nichicon UHE. I was looking for 1000uf 10v 8 x 20 mm. If you'll look into data, you'll see that impedance at 20 and 10 degress celsious is same, same applies for the ripple current. Also, I saw same thing with some other big caps(680uf 400v, or something like that, don't remember exactly) and saw same thing from NCC and Nichicon, no other manufacturer. This leads me to one idea - they are using same factory and just rebranding some caps.
            Any opinions on this one ?
            10-15-2021, 03:23 PM
          • slybunda
            AA and AAA battery charger capacitors?
            by slybunda
            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
            it has inside:
            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
            2 x 470uf 16v LZ105c branded as G.Luxon
            not heard of these brands are they any good?
            iv attached photos of the charger and the board inside for an idea on the type of...
            12-24-2023, 04:41 AM
          • Hitto
            Fake Nichicon capacitors with almost-perfect sleeve?
            by Hitto
            Fake Nichicon capacitors with an almost-perfect sleeve?
            Same font, perfect logo, same size of the sleeve. The air vent looks okay. The diameter of the capacitors is correct per datasheet.
            It truly looks like the real thing.
            I doubt that you would distinguish it from a genuine one.. if it wasn't for the bung.
            Shall we be afraid, at this point, that even the bung can be replicated?...
            01-09-2021, 03:07 PM
