Some useful pointers on recapping your board
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16951
    If you have questions about the actually your board, post that here. This would include soldering tips, tools to use, capacitor values, capacitor brands, places to purchase caps, and anything else that you can think of that covers the removal/installation of your new caps.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • ncdave
    • Oct 2003
    • 33
    capacitor sources, etc.
    http://www.burtonsys.com/bad_BP6/ has some info and links about the bad capacitor problem, including a source for inexpensive 8mm(?) diameter 1000uF 10v replacement capacitors, and a possible source for free aluminum electrolytic replacement capacitors.
    -Dave
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • canadaboy25
      Panasonic TC-P54VT25 No image. A or D board?
      by canadaboy25
      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
      01-17-2021, 01:06 AM
