Hi all
I guess I need some assistant. Not sure if I should be worry or not. You know Overcharging/Undercharging batteries are a NONO. LOL! I had my charger for awhile and its been good till now. The only issue that I am having is the voltage its reading is about -0.02 off. For IE 2 of my testers are reading my battery @ 4.20 and the charger is now reading it as 4.18. 0.02 difference me to it may not be a big deal but I am not the TECH here all of yall are the TECHS. LOL!
I opened the charger and all looks good no burn marks no odd smell. (I am not a TECH). The only thing I did noticed is that the capacitor is 35V 680UF that the manf installed. Under the capacitor the board says 35V 1000UF.
Can that be my issue or its fine and just leave the charger alone as its working fine just the volts are little off?
Any info would be great.
P.S. I do have some GREEN Sanyo 35V 1000UF 105*C WG laying around. Are they good if I should change it? Also I can post a picture the inside of the charger if you need it.
Thanks again.
Thanks again.
Half of the computer problems is caused by bad contacts
