This section is here if your system has become unstable and crashprone, and you've tried everything else and can't seem to figure out what the problem is.
Bad capacitors are more common than one thinks, affecting MANY motherboards by many manufacturers. Abit by far has been hit the hardest by this, but I've seen plenty of other popular brand boards die from this.
If you question your caps, post here with your symptoms and we'll try to get it figured out for you!
