assessing internet purchases
  • halaster79
    • Jul 2016
    • 39
    • usa
    why do Rubicon MCZ caps tend to have lower UF than whats shown on the side of the caps? it still is in 20% tolerance though. numbers include like 1140 uf for a 1200 uf 6.3v MCZ cap. these are dated 2010 caps bought from badcaps and the cap king.
  • halaster79
    • Jul 2016
    • 39
    • usa
    Re: assessing internet purchases
    my 2005 nichicon hm 1500uf 6.3v all seem to be in 1770 to 1830 range for uf. are they good?
      • 31026
      if the uF is noticably higher, can you read the leakage level or ESR on your tester?
      i have seen capacitance rise with leakage, strangely the ESR goes down as it happens.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4954
        • New Zealand
        They may have lost a little capacity over time from not being used, in any case, 1140uF for a 1200uF capacitor is pretty good.
        AFAIK, Nichicon HM from ~2005 are not known to be very good! Yours may be showing higher capacitance from higher leakage current.
        You need to check ESR and leakage current if you want to be really sure a capacitor is OK.
        -David VanHorn
        • halaster79
          • Jul 2016
          • 39
          • usa
          i thought they were ok as long as they are in the range of +- 20% capacitance according to the datasheets? 20% of 1500 is 300, so wouldn't around 1800 be ok? on a 1500 cap read by a honeytek a6013L at 2000uf
          • Agent24
            I see dead caps
            • Oct 2007
            • 4954
            • New Zealand
            If the datasheet specifies the tolerance as +/-20% and they are within that, then sure, they are "within tolerances"
            But. Manufacturing has improved over the decades, and it's not usual to find capacitors that are markedly different from the labels.
            -David VanHorn
            • halaster79
              • Jul 2016
              • 39
              • usa
              i'm trying to figure out how to use a mesr-100 v2 esr meter now
              • halaster79
                • Jul 2016
                • 39
                • usa
                what does - 0 to 1 r mean? its reading .006 at that
                  • 31026
                  0.006 ohms esr
                  • halaster79
                    • Jul 2016
                    • 39
                    • usa
                    is it normal for the ESR to be lower than what it says in the datasheets? especially when it says the ESR number is for ESR max in the datasheets?
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4954
                      • New Zealand
                      Yes. The datasheets show the maximum the ESR can be for a good capacitor. The actual parts may well have an ESR which is lower.
                      -David VanHorn
                      • halaster79
                        • Jul 2016
                        • 39
                        • usa
                        do you guys consider the mesr-100 version 2 to be a good ESR reader?
                        i use an ideal 61-342 multi-meter and a honeytek A6013L capacitance tester to check capacitance. it takes the ideal longer to read it.
                        • salimov
                          i need bios hp pavilion dv6 1140 ek
                          by salimov
                          my friend
                          main board.DAUT3DMB8D0 REV.D
                          intel processor
                          bios dump
                          12-02-2019, 09:49 AM
                          DELL Inspiron 5577 Notebook 5000 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 5577 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5577 boardview and 5577 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5577...
                          09-06-2024, 08:01 AM
                        • withalligators
                          Looking for best replacements for Capxons, but can't find data sheets
                          by withalligators
                          Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                          1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                          1 x Capxon 1000uf35v...
                          03-25-2022, 02:30 PM
                        • japlytic
                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                          by japlytic
                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                          Tried (only with keyboard/mouse connected):
                          • BIOS + database update
                          • Using latest Windows 11 image built with official image creation tool
                          • Previous setup version for Windows 11 installer
                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                          06-19-2025, 04:59 PM
                        • Habble7
                          Lenovo ThinkVision P40w-20 no power – ILPI-422 VA board repair help
                          by Habble7
                          I'm trying to repair the power supply board from a Lenovo ThinkVision P40w-20 monitor. The board is labeled with the following markings:
                          - Main PCB code: ILPI-422 VA (dated 2021/11/24)
                          The monitor is completely dead, no power LED or backlight. Upon inspection, I found a few components that appear damaged, particularly some resistors that are burned and unreadable.
                          Attached is a high-resolution photo of the power supply board.
                          Does anyone have a schematic, boardview, or similar power supply that can help identify the...
                          05-15-2025, 02:38 AM
