Rubycon MBZ availability/replacement?
  • Kleist
    • 15
    Hi Everyone,
    I have a DFI board with a bunch of blown chemicon KZGs which I would like to replace with Rubycon MBZs but I cannot find them in stock anywhere, are these still for sale?
    Are there any good replacements for the Rubycon MBZs?
    Thanks!
  • mockingbird
    • Dec 2008
    • 5488
    Re: Rubycon MBZ availability/replacement?
    Please post pics of your board.
    EDIT: Ok, you made a different thread here: https://www.badcaps.net/forum/showthread.php?t=58686
      • 31296
      MBZ / MCZ are discontinued years ago, if you see any on sale they are past it or fakes.
      replace them with polymer caps.
      • Kleist
        • 15
        I am somewhat hesitant to replace them with polymer caps not knowing enough about the implications on the circuit, I would rather a direct replacement.
        Are there no more good electrolyte aluminum caps being sold?
        I looked into the Panasonic FM already but they are not the same size as my KZGs.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          new old stock is all there is for MBZ/MCZ. what value are you looking for?
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • Kleist
            • 15
            Hi Topcat,
            What do you mean by value? How long do I want them to last?
            This motherboard (DFI Lanparty NF4) is more than 10 years old so whatever caps I put on here will probably outlive the rest of the components. That being said I would like to convert this into a small home server so the uptime will be near 24/7 and it will accumulate a lot of hours relatively quickly.
            Did you have anything in mind?
            • Kleist
              • 15
              I now realize that by value you probably meant what capacitance and voltage I need...sorry it was a long day at the office
              I would ultimately like to change all the chemicon caps on the board, here is my shopping list:
              Visually Bad:
              KZG 1500uF 6.3V (8x18mm??): 2
              KZG 470uF 16V (8x11.5mm): 7
              Visually OK:
              KZG 1500uF 16V: 5
              KY 1000 uF 6.3V: 3
              KY 100uF 25V: 14
              KMG 470uF 6.3V: 2
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                Visually Bad:
                https://www.badcaps.net/store/produc...products_id=39
                https://www.badcaps.net/store/produc...products_id=51
                KZG 1500uF 16V: 5
                https://www.badcaps.net/store/produc...products_id=38
                Visually OK:
                KY 1000 uF 6.3V: 3
                KY 100uF 25V: 14
                KMG 470uF 6.3V: 2
                Those wont cause you any trouble.
                Team : 49813
                Join in!!
                Team Stats
                • Kleist
                  • 15
                  Wow spot on Topcat, take my money!
