First re-cap..seems ok..
  • andycaps
    • Sep 2008
    I just finished recapping my first motherboard (for a Dell GX270). Everything seems to be working properly, system powers up fine, boots into OS with no problems... Is it safe to say this board is fixed? Or is there something else I can do to ensure I did this correctly
    Thanks!
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: First re-cap..seems ok..
    run memtest86+ at least 2 passes or overnight
    run some burn in utility in windows
    its probably fine
    • Agent24
      I see dead caps
      • Oct 2007
      • 4970
      • New Zealand
      Originally posted by andycaps
      Thanks!
      As long as the new caps you used are good quality then you did it correctly
      If you screwed up the soldering then I doubt it would be running now...
      -David VanHorn
      • BrentH561
        Elitedesk 800 G6 SFF Bios Password Lock XM25QH128A (3.3v) - Am I doing this right?
        by BrentH561
        Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
        Here is the hardware identification specs:
        HP EliteDesk 800 G6 SFF
        Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
        Serial No: MXL1223499
        Product No: 26S74UT#ABA
        BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most
        08-23-2024, 08:36 AM
      • abajor
        A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
        by abajor
        Having this very weird issue.
        The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
        I swapped with a working screen from an A2141 waiting for parts.
        The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
        The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
        04-27-2024, 01:37 PM
      • DynaxSC
        ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
        by DynaxSC
        I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
        Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
        Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
        The behaviour is also really very strange, i.e.:
        • The disk shows always up in BIOS - so it is recognized, so far so good
        • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
        02-23-2025, 01:33 PM
      • pepebmx
        ThinkPad T14 Gen 3 - Boots Only on Charger
        by pepebmx
        Subject: Lenovo ThinkPad T14 Gen 3 - Boots Only on Charger, Fan Spins Full Speed with Battery
        Laptop: Lenovo ThinkPad T14 Gen 3
        Serial No: PF-437QTG
        PCB: NM-E441 Rev 1.0 (JT4C1/JT6C1/JP6C1)
        Extracted BIOS: Will upload tomorrow
        BIOS Password: None Issue Description:
        • Boots only on charger → Works normally when connected to AC.
        • With battery connected:
          • Fan spins at full speed, no display.
          • Not all voltages present (some missing).
        • Battery charges correctly (detected in Windows, shows percentage).
        • When battery is plugged in while in Windows:
          • Laptop shuts
        05-08-2025, 01:53 PM
      • pete18064
        ASUS ROG STRIX G512LW Help
        by pete18064
        After flashing firmware the laptop boots into the BIOS, but I get a flash of the logo, and then it goes to black screen the majority of the time. There have been times when it boots into the BIOS and the logo flashes in the center of the screen and it goes to black screen. Then, there have been times when it boots into the BIOS, but only half of the screen is visible. The BIOS screen is completely visible, cropped into half of the screen. What would the suggestions be in this case? I suspect the GPU has solder issues, but I am not sure.
        I wanted to add that I checked to see if there...
        02-21-2025, 05:06 PM
