Capacitor Brand
  • TiagoKaeshi
    • Aug 2016
    • 8
    • Brazil
    Capacitor Brand
    I've removed this cap from my old 200W atx power supply (Feb/2000). It was used 5 times a week everyday till it stopped last week because of bad soldering. Some 220uF or low were CapXon ones and all other 470uF/1000uf/2200uF were this ''A'' brand that I can't seen to find the manufacturer.
    So here it is: rated as Low-ESR! Here's the test that I did with my 'cap-miter':
    16v/470uF rated = 466uF real
    16v/1000uF rated = 998uF real
    10v/2200uF rated = 2194uF real
    That's just like a pro capacitor! I've tested some EPCOS and LeLon capacitors that reached 10% difference! Like 905uF on a 1000uF EPCOS and 374uF in a 470uF LeLon capacitor, all rated ''Low-ESR''
    Here's some pics so maybe someone know the maker of this thing. (sorry for my english, i'm from brazil)
    • 31170
    Re: Capacitor Brand
    ARK ELECTRONIC CO., LTD
    http://www.arktwn.com.tw/
    • TiagoKaeshi
      • Aug 2016
      • 8
      • Brazil
      Re: Capacitor Brand
      Thank you so much!! It's interesting how I couldn't find any place to buy them, maybe ARK went bankrupt? Look at the website, is like 17 years old since the last update.
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Re: Capacitor Brand
        Given the age of the P/S, if you're looking to replace that cap Nichicon PW series or United (Nippon) Chemicon LXZ series would probably be similar or a bit better.
        PeteS in CA
        • MORETTIGIAN
          Capacitor detached from PCB – RTX 2070 Super Founders Edition
          by MORETTIGIAN
          Title:
          Description:
          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
          I did not notice it detaching, so I am unsure of its original location on the PCB.
          Procedure performed:
          - Removed backplate
          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
          - Reapplied thermal compound
          - Reassembled card
          Observed behavior after reassembly:
          - GPU powers on and operates normally under...
          09-18-2025, 12:14 PM
        • Prolog
          RTX 3080 FE Identifying capacitor
          by Prolog
          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
          I hope these photos make it clear which component I am referring to:
          (yes, the soldering is a bit botched from removing the blown one, I know)
          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
          12-01-2024, 08:27 PM
        • chth96
          If I replace with inferior capacitor, Is it No harm to other IC components at all?
          by chth96
          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
          I know that these capacitor will not last as long as nichicon capacitor...
          12-22-2023, 04:34 AM
        • chth96
          How can I test non-polarized capacitor?
          by chth96
          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
