Help identifying a SMT Aluminium Cap
  • capacitor_bob
    • Aug 2008
    Hi Guys,
    I have searched google and the forum for help on identifying this cap off a MB from an Axis 2120 Network Camera but no success. Here is what I know:
    It is an aluminium surface mount electrolytic cap, with a 'K' vent (it is blown!)
    On the top it has a black edge indicating the polarity. However the only other markings are:
    29
    470
    25 A
    Can someone help me with those please? I can find a reference that I am confident in because most have a different combination.
    Thanks for your help.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Help identifying a SMT Aluminium Cap
    Just guessing:
    25 is the only number that is a standard voltage.
    470 is no doubt the uF.
    That and it's size is all you really need to know to replace it if you choose high grade (Low ESR) replacement.
    High grades work okay where low grades were but not the other way around.
    Mann-Made Global Warming.
    - Dr Seuss
    • trodas
      • Jan 2006
      • 770
      • Czech republic
      Well, not all the time and almost NEVER in PSUs...
      As for the SMD cap, then there is a reasonably big shortage of really GOOD SMD caps. In Digi-key, for example, are the best SMD elyte cap I find so far Panny FK ones and their specs are more mediocre that I would like...
      There are few Os-con SVP polymers I got from Big Pope, but not 25V ones. Only 16V ones. Sadly it is blown up, so measuring how much voltage are REALLY on the cap is not possible anymore...
      So, what "high grade (Low ESR) replacement" precisely you got in mind, PCBONEZ...?
      "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
      "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        By grade I mean ESR and ripple.
        uF and volts has nothing to do with grades.
        - Dr Seuss
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          its likely a gp lytic.
          without seeing the circut its hard to tell.
          wont hurt to use a panasonic fm or similar.
          if space is not an issue a radial lead part may work.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            That's what I meant by:
            > High grades work okay where low grades were but not the other way around. <
            Fail up to a good grade and it should be fine.
            Pany FM sounds ideal.
            - Dr Seuss
            • trodas
              • Jan 2006
              • 770
              • Czech republic
              Me too. Best ESR and ripple values (for high frequency at least) are polymers, but they fail to reach the 25V voltages... So as you see, "uF and volts has" everything to do with the grade choice.
              The rest of available (at least to me) SMD caps are more like mediocre specs.
              You guys talking about Panny FM, but Panny FM is NOT made as SMD one, just check datasheet of Digi: "No records match your search criteria" ...
              And the Panny FK is more like mediocre cap:
              Panasonic FM 2200uF 16V - impedance 0.015 - ripple 3190 (7 000 h) 12.5x25
              Panasonic FJ 1800uF 16V - impedance 0.012 - ripple 2800 (3 000 h) 10x25
              Panasonic FK 3300uF 16V - impedance 0,035 - ripple 1800 (5 000 h) 16x16,5 SMD
              Panasonic FK 1500uF 16V - impedance 0,060 - ripple 1100 (5 000 h) 12,5x13,5 SMD
              Samxon GC 1800uF 16V - impedance 0.009 - ripple 3190 (2 000 h) 10x25
              Samxon GA 1800uF 16V - impedance 0.0065 - ripple 4140 (2 000 h) 10x25
              Samxon GD 1800uF 16V - impedance 0.012 - ripple 2800 (2 000 h) 10x25
              Nichicon HZ 1800uF 16V - impedance 0.0065 - ripple 4140 (2 000 h) 10x25
              Nichicon HN 2200uF 16V - impedance 0.009 - ripple 3190 (2 000 h) 12.5x20
              Rubycon MCZ 1800uF 16V - impedance 0.009 - ripple 3230 (2 000 h) 10x25
              Rubycon MBZ 1800uF 16V - impedance 0.013 - ripple 2800 (2 000 h) 10x23
              Yep, I recently did that in my Motorola SB5100 modem:
              https://www.badcaps.net/forum/showthread.php?p=52940
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                uF and volts has as much to do with grades (ESR and Ripple) as what color they are.
                uF and volts sets requirements within which you must to find an adequate grade.
                FM is good choice when you don't know the grade of the original.
                I did forget the problem cap is SMD.
                FK is better than HE or KY but less than ZL or KZE.
                The cap in question is apparently a Sanyo CE-AX series.
                Sanyo CE-AX 470uF 25V - impedance 0.090 - ripple 670
                And a Pany FK will do just fine
                Panasonic FK 470uF 25V - impedance 0.080 - ripple 850
                - Dr Seuss
                • AstutePauciloquent
                  Requesting Help Identifying tiny Aluminium electrolytic
                  by AstutePauciloquent
                  Hi wonderful people. I have a MS-6315 P3 motherboard with very tiny Aluminium electrolytic capacitors. I've made an attempt to identify them from what ive learned so far they might be
                  Aluminium Electrolytic
                  G = Series
                  10 uF
                  16 = Volt
                  104 Date code 2001 April? (not really important, but interesting)
                  Please help to confirm or correct if i am wrong. Thank you
                  10-20-2023, 06:29 AM
                  HP Elite 7300 MT Elite 7300 i3-2120 Specification for Upgrade or Repair
                  This specification for the HP Elite 7300 MT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite 7300 MT boardview and Elite 7300 MT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Elite...
                  09-12-2024, 03:44 PM
                  HP Compaq Pro 6200 Compaq Pro 6200 i3-2120 Specification for Upgrade or Repair
                  This specification for the HP Compaq Pro 6200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro 6200 boardview and Compaq Pro 6200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                  LENOVO ThinkStation E31 ThinkStation i3-2120 Specification for Upgrade or Repair
                  This specification for the LENOVO ThinkStation E31 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation E31 boardview and ThinkStation E31 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-12-2024, 03:36 PM
                  LENOVO ThinkCentre M81 ThinkCentre M i3-2120 Specification for Upgrade or Repair
                  This specification for the LENOVO ThinkCentre M81 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M81 boardview and ThinkCentre M81 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
