Can anyone identify this capacitor?
  • SigBoi
    • Jun 2016
    • 6
    Hey everyone, my mechanic narrowed my climate control issue down to these two capacitors on the climate control circuit board.
    Let me know if taking photos from different angles would better help identify them!
    I am not familiar with how to identify these and where to order new ones.
    Any help would be greatly appreciated!
    Thank you
  • mockingbird
    • Dec 2008
    • 5484
    Re: Can anyone identify this capacitor?
    I can't track down the manufacturer, but it's safe to assume they're 50V 100uF caps.
    This should be a suitable replacement:
    http://www.digikey.com/product-detai...09CT-ND/766185
    Please double-check the diameter. I'm assuming these are 8mm wide (measured by the size of the can).
    • SigBoi
      • Jun 2016
      • 6
      Thanks for the info! I'll see if I can get a shot of it next to a ruler. And I think they are a little taller than the one you linked to.
      • mockingbird
        • Dec 2008
        • 5484
        10.50mm is the standard height for an 8mm SMD cap for that spec... Are you sure?
        • SigBoi
          • Jun 2016
          • 6
          Here are more photos and measurements of the capacitors.
          They are 8mm in diameter and 9mm tall.
          • mockingbird
            • Dec 2008
            • 5484
            The one I linked to should be good.
            FYI, here are the heights that exist for this cap in 8mm:
            10mm
            10.2mm
            10.3mm
            10.5mm
            10.6mm
            11mm
            11.5mm
            You might also want to change that small little one I see there in the picture if it's the same brand.
            • SigBoi
              • Jun 2016
              • 6
              I think you are correct, I got mislead by the photo on the link you provided, as it looked short from the photo.
              I also think I measured wrong to get 9mm. I did not include the black base, just the silver part.
              If you can look at the photos I posted earlier and confirm that would be great! Thank you!
              • SigBoi
                • Jun 2016
                • 6
                And so 10.5mm height is the most common one? Also, what size do you think the small one would be? I need to get back to the shop to measure the little one.
                Thank you again!
                • mockingbird
                  • Dec 2008
                  • 5484
                  Yes, the photo on Digikey is just a stock photo for that series, and doesn't represent the exact size of the part that's in the specifications table on said page.
                  Thank you again!
                  Yes, 10.5 is the most common. I think the small one is 6.3mm. Ok good luck measuring
                  • Brian_STI
                    • Jul 2015
                    • 10
                    • united states
                    BTW, seems like a lot of people don't know how you go about replacing these caps. With these you want to cut them, cut them? I know, it seems weird but take some cutters and cut them just above the black plastic, cut them completely off. Then the plastic piece and leads are left attached to the board. You slide the plastic piece off then desolder the leads as normal.
                    To replace the cap, treat it like any other surface mount component.
                    • BlackBurn
                      Help to identify a laptop mainboard SMD capacitor LA-9982P
                      by BlackBurn
                      I have an Dell Inspiron 15 3537 laptop mainboard (LA-9982P Rev. 3.0 (A02)) with a blown SMD capacitor as shown in the attached images. However, there is no printed specifications near the capacitor or a codename for the capacitor to identify the specification of the capacitor to replace it. I wonder how to identify the capacitor since the mainboard schematics are also useless as the capacitors are not named on the board. Any help would be highly appreciated.
                      Thank You. Stay Safe.
                      Chamara...
                      11-27-2020, 08:30 AM
                    • chth96
                      by chth96
                      12-22-2023, 04:34 AM
                    • chth96
                      by chth96
                      06-02-2024, 07:31 PM
                    • chth96
                      Is it no harm to replace with capacitor without ripple current rating?
                      by chth96
                      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                      Rubycon YK DataSheet (b...
                      04-19-2024, 05:19 AM
                    • chth96
                      Should I replace polymer capacitor?
                      by chth96
                      a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                      I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                      Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                      Is this ESR value of polymer capacitor correct?...
                      11-18-2022, 04:22 AM
