Sparkle nvidia 9800GT and Sacon FZ capacitor
  • 250gto
    • May 2016
    • 6
    • Italy
    I found a blown capacitor on the video card in object and I detached it with a soldering iron.
    The capacitor is a FZ7A 1000microF 16V.
    I already read a thread about these Sacon FZ series on Sparkle video cards, and from there I know that the ripple current is 1800mA.
    I already read the thread about where to buy capacitors.
    I would like to know if this capacitor in the next link could be right to replace the blown one:
    http://www.digikey.it/product-detail...ur=EUR&lang=en
    Thank you for your help
    Leonardo
    • 30997
    Re: Sparkle nvidia 9800GT and Sacon FZ capacitor
    no problem electrically, just make sure the distance between the pins is the same.
    btw, you should replace all FZ's - but you probably know that from other threads.
    • piernov
      NVidia bumpgate
      by piernov
      Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
      Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
      May complete this post at a later date with more details.
      Basically issue is a combination of thermal dissipation of the chip with hotspot,...
      03-27-2021, 10:34 AM
      NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
      The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
      10-02-2024, 08:52 AM
      NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
      The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
      10-02-2024, 07:51 AM
      NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
      The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
      10-01-2024, 01:54 PM
    • Prolog
      RTX 3080 FE Identifying capacitor
      by Prolog
      Hi people, I hope this is the correct spot to post this, I'm new to the forum.
      I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
      I hope these photos make it clear which component I am referring to:
      (yes, the soldering is a bit botched from removing the blown one, I know)
      I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
      12-01-2024, 08:27 PM
