bad? main power board?i think?
  • medamotcha
    • Jun 2008
    • 66
    well hello..yall..i have a 42' tatung plasma hd tv..well we were watching and it just shut off..well i tryed everything..i even called the company..what i told them..thay said it sounds like the main power board...thats as far as i got with them..lol..never called me back..ok any way...well i turn off the tv and the power.turn it back on..ok the power came on...the fan in the back you could hear come on..than it would do a boot(normal)turn off and back on..for a breaf sec.you could hear the fan turn on and click and click again
    and stop...you sould see three lights in the back first thay were green the one would turn red..thats it..the tv would not go any ferther..the screen was blank...sometimes you could here the scrachy channel,( snow noise).....but sometimes i would get a blue screen?...now thair was a lot of dust caked up near the fan..... got to have power becose i took off one of the jumpers and the fan would go and not stop.but no pic...put the jumper on the fan would turn off...can anyone help me?dose it sound like the caps need to be replaced..but i inspected them..and thay done look bad..dont look pop'ed or oozing..but could thay still be bad?the board looks good not burn't..can any one help me please????? thx
    bad caps make me crazy
  • medamotcha
    • Jun 2008
    • 66
    Re: bad? main power board?i think?
    please help me!!!!i really miss my 42' tv..am i in the right section?
    • Leopard
      • Mar 2008
      • 109
      • Finland
      Caps can fail without any visible signs. It would be helpful if you posted some info about the caps. Namely their brand and series... And pics never hurt, either
      • medamotcha
        • Jun 2008
        • 66
        thx i found i them....im looking in to the kind that i need....now if it only a couple of little caps should i replace (all), small and big?or can i just replace the ones that r leaking...it wasent my main power board..ill get back to ya......im going to find the ones that i need.....thx.you have a good one
        thay look like these...i have to get the numbers yet..
        • medamotcha
          • Jun 2008
          • 66
          what type are these silver one's ....thair about 4 that r leeking...had to really look...leeking from the bottom..you couldent tell...but the board had like oil next to the caps that r bad
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • Asraf Atb
            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
            by Asraf Atb
            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
            01-27-2025, 05:02 PM
          • JSin21
            Compatibility of main boards between different variations of samsung MU6100
            by JSin21
            Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
            I have Samsung Smart TV UA65MU6100WXXY version DA01
            Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
            11-27-2023, 04:54 AM
