Tried to turn my CNC machine on last week, and got nothing. Checked and found low voltage on the main output. (5v)
Found a couple caps with high ESR and figured I would replace all the electrolytic caps.
This is on a Deltron 4 output power supply. (+5,+15,-15,+24.)
Thing was made in 1990, all the caps have 1990 date code on them.
Seems like none of the exact caps are made anymore because of the lead free rules.
So, based on the info I could find, and what Digi-key had in stock here are my choices:
Everything was rated 85c, 20% and 2000 hours.
1200uf, 200v had Nichicon LK, replace withVishay 157 PUM-SI
2200uf, 35v had Chemi-con SME, replace with Chemi-con SMG
1000uf, 35v had Elna RE, replace with Nichicon UKL
220uf, 35v had Elna RE2, replace with Nichicon UKL
4700uf, 10v had Elna RE2, replace with Nichicon UKL
100uf, 16v had Shoei ?, replace with Nichicon UKL
Thanks, Jim
Thanks, Jim
