Ocilloscope Issue
  • coreAngel
    • Oct 2014
    • 124
    Ocilloscope Issue
    Hello,everyone i have an issue i really need your help, i bought an ocilloscope on ebay one of those DIY kits,
    DSO138 2.4" TFT Digital Oscilloscope Kit DIY parts ( 1Msps ) with probe
    and the electrolytic caps that came with it 4 of them, 2 have the bung pushed out when i look at the manufacturer it's Cheng craps.
    So i wanted to ask i wanted to choose other caps or poly's they are very small caps
    would general purpose caps work, low impedance caps ,or very low esr?
    thanks for your help
    Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboard
    • 31214
    Re: Ocilloscope Issue
    size of the can, distance between the wires, rating of the caps please.
    • coreAngel
      • Oct 2014
      • 124
      Sorry i thought i posted the specs, the caps are small 16v 100 microfarad Cheng fakes i believe..it says Chng
      distance between leads is 2mm
      And the cap is 6mm high
      • coreAngel
        • Oct 2014
        • 124
        Any help would be appreciated.. i just don't know what would be good, low esr, caps..etc
        these are my choices
        http://www.mouser.com/ProductDetail/...%2fXYbMkdFI%3d
        http://www.mouser.com/ProductDetail/...MWtkd2mWibI%3d
          • 31214
          without more info on the fakes or a schematic, it's hard to help
          personally i'd just stuff it full of panasonic FR - but i do that with everything!
          • coreAngel
            • Oct 2014
            • 124
            thanks i might go fr, or all poly's
              master hoarder
              • May 2008
              • 12175
              I doubt you need low ESR caps in there. General purpose 105C should be fine. But given that there is little difference in price between low ESR and general purpose, you might as well go low ESR.
              How "low" ESR?
              - Doesn't matter. If the original caps were intended to be Cheng/Chang/Chong crap, the scope was probably never designed to care anyways.
              That said, I would *avoid* aluminum polymer caps - they have much higher leakage than regular electrolytic caps (about 10x higher), and that can cause drifting and DC biasing issues with sensitive amplifier inputs. So it is best NOT to use polymer caps.
              On that note, general purpose 105C electrolytic caps usually have lower leakage current than low ESR caps.
              So again, I would just do the whole thing with quality Japanese GP and maybe low ESR caps if the latter is cheaper.
                by momaka
                03-12-2025, 03:42 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • bcstedt
                LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
                by bcstedt
                LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
                Problem:
                On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
                It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
                01-18-2024, 01:03 PM
              • EFritz20
                [Retro] Asus A7N8X Deluxe Rev2.0 Power issue related to caps?
                by EFritz20
                Hello all,
                I have had this motherboard for a long time and started trying to use it again.
                As alot of you know its a Socket A(462) motherboard from the bad caps era.
                Mine contains Rubycon MBZ 3300uf as VRM in and output. The caps look fine from the outside but the board itself has this problem;
                If i turn the power off (completely unplugged for >30min) and then turn it on, the board will post just fine and i'm able to go into BIOS, modify it, save it and actually boot from it. Earlier I was able to install Windows on it, but now, just before it goes into...
                08-14-2021, 07:10 AM
