Hissing Caps?.
  • Speakersrock
    • May 2008
    • 6
    Hissing Caps?.
    Hi there,
    Just wnated to ask, as I not seend it anywhere, Is there a possibly a cap. going bad could hiss?!?
    Thanks.
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Hissing Caps?.
    Well they do often build up pressure when they go bad. So if the leak was slow enough, they may make noise.
    That's probably not what you're hearing though. If it's enough to where you hear it, then it most likely would not last very long due to there simply not being much water in there to boil out.
    Unless there's visual symptoms, such as leaking / bubbling electrolyte and / or a bulged vent, you're probably hearing something else, like a coil vibrating or something.
    A man convinced against his will is of the same opinion still.
    • kikkoman
      • Jul 2007
      • 691
      Re: Hissing Caps?.
      the plastic sleeve could be the source as well if the cap vibrates.
      a coil is more likely, though.
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        Re: Hissing Caps?.
        its coil noise.
        often caused by bad caps.
        or one of your kids pet hissing roaches got inside! ;-)
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
