I have a used 6VTXDR-C board from gigbyte with a curious problem: It will boot and POST just fine with one cpu, but when I add the other cpu it wont POST. The cpus are identical PIII-S 1.4Ghz SL5XL with the 512KB L2 cache. These chips are supported by the board, and they do support SMP. At first I suspected that it was bad caps, so I had all the caps replaced (except for the known good Rubycons). The result was absolutely no change at all - it still only POST's with one cpu. Both CPU's are new (I upgraded from an old single Celeron), and they will each work when placed in the first socket. There are no burns or deformations around the VRM mosfets, but one of the rings (I am not a real hardware guy - I'm a programmer) with wire wrapped around it is very slightly discolored. Has anyone any ideas? Could it still be the remaining Rubycons that are fried - how can I test this?
GA-6VTXDR-C won't post with 2nd CPU
Re: GA-6VTXDR-C won't post with 2nd CPU
cmos cleared, tried each cpu in turn in each socket. Same result every time. Putting either one of the CPUs in socket 2 causes a no POST. Putting either one of the CPUs in socket 1 alone will POST. The odd thing is that if I put a PIII-S in socket 1 and a celeron it socket 2, it will post, but it doesn't recognize the 2nd CPU (and this is exactly what it is supposed to do - a celly and a PIII-s don't supoort SMP).Comment
by ugamazingI have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%... -
Hi guys!
I have a Dell Optiplex 760 USFF (Ultra-Small Form-Factor).
It currently only supports Dual-Core CPUs and will halt with an error message, when a QuadCore is installed.
I have seen people running QuadCores in these machines, but the BIOS needs to be modded.
Since I have not found the modded BIOS to download anywhere, I am asking you guys for help:
Could you please add support for QuadCore CPUs (in my case the Core2Quad Q9550) to the BIOS?
I have attached the Dump of my machine.
S/N: SRW2K4J
Reg Model: DCTR...-
09-27-2024, 02:43 AM -
by ducky29Hello. I mostly do small electronics and tv repairs. I am confident with small bga chips but I never was successful with removing large chips especially cpus. Is it possible to remove them just using a preheater and hot air gun or I need something more advanced like a bga machine with temperature profiles, cooling fans, etc etc.
Any suggestion on aliexpress/ebay are welcomed. I am on a tight budget, max I can do is about 200$. Please anyone with more experience can give me some suggestions?
Thanks in advance.09-23-2024, 03:56 PM -
Recently I came across an x570 Aorus Elite where the temperature in bios was reporting -55c, i had checked the CPU_TEMP line connected to the IT8688
In my particular case, the SIC line going to the X570 chipset (PM_SIC) was shorted to ground, so far disconnecting the 0 ohm resistors connecting APU_SID and APU_SIC to the chipset has fixed my -55c issue, it seems like -55c is the fallback reading for CPU_TEMP which is just pulled up to VREF on most gigabyte motherboards
I wanted to post this as even the ever-reliable vlab forum was stumped on this issue
tags:...07-28-2025, 07:26 PM -
by bigbearkAccordng to the ASUS website, if you apply BIOS 5001 you can use Socket AM3 CPUs on the M2N-E motherboard.
I have two of these boards that are working. The CPU support info on the ASUS site says you can use ATHLON II X2 CPUs, Athlons II X3, and even Athlon II X4 CPUs.
These CPUs seem to be readily available at reasonable prices. There are some that consume as little as 45 watts.
The notes say "Due to Bios ROM size limitation remove LAN PXE ROM and change Crashfree3 to Crashfree".
I assume these are options in the BIOS setup you can... - Loading...
