Bad Capacitor then??!
  • Speakersrock
    • May 2008
    • 6
    Hi there,
    I just want to clarify before I take any action to fix it;
    I have an newish (but not under guarantee) DVD player here.
    It has packed up, and does not even power on. (Yes, have checked the fuses
    I noticed 'orange stuff' at the bottom of the capacitors and imminently thought of this great site.
    Do you think this would probably be blown caps?
    Here are some very badly taken images which might help!
    Any advise would be much appreciated!, Thanks.
    http://heavens-end.co.uk/share/PHOT0011.JPG
    http://heavens-end.co.uk/share/PHOT0009.JPG
    http://heavens-end.co.uk/share/PHOT0010.JPG
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Bad Capacitor then??!
    looks like glue
    • Speakersrock
      • May 2008
      • 6
      oh right!
      But if it were glue would it not be on all the other capacitors too??
      Thanks for the responce.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        your logic is flawed
        • zandrax
          Hit and miss
          • Dec 2007
          • 1157
          • Italy
          Not always: most of times only big capacitors need to be secured to the board with glue.
          Anyway I agree with willa: it seems glue because electrolite smells bad (do you smell it?) and it would have been leaked into a pool.
          Zandrax
          Have an happy life.
          • Speakersrock
            • May 2008
            • 6
            oh right. Okay. I guess you are right there then
            If it was leaked stuff, it would be hard by now??
            Thanks for your continued help.
            • Speakersrock
              • May 2008
              • 6
              Im only assking if it would be hard or not, in the terms of, if I touched it, and this stuffcrumbled or something, I would know its not glue.
              ...That logic is incorrect too?
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                caps are secured at the bottom by a bung. this is pretty much guaranteed to be airtight otherwise i believe you would be looking at very early drying out of the cap.
                with some cheap manufacturers the bung is not made of quality synthetic rubber so it gets hard with age and temperature and then when the capacitor is failing and producing gas, the first thing to go is the bung not the vents at the top.
                so this makes leaking at the bottom of the cap but it also makes the cap pushed up or leaning over
                if you scroll down
                http://www.capacitorlab.com/visible-failures/index.htm
                so on the basis that
                - the caps are not leaning or pushed up
                - the material in dispute is in a horizontal line across the negative stripe which seems odd if something was leaking
                - it looks like one type of glue i am familar with seeing, others are more obvious like white stuff or clear hot glue
                i think it is glue
                now that does not mean the caps are not off spec. this could be proven by using esr meter or maybe capacitance meter, or otherwise by replacing them and seeing what happens
                still, other components could have failed in this power supply. so you will need to start testing.
                • Speakersrock
                  • May 2008
                  • 6
                  okay, thanks very much for all that info, was very, very useful!
                  I guess I had better start testing then yes. - Or as you say replace the capacitors and see.
                  Many thanks for all the help everyone.
                  Take care - and well done on such a great site and forum!
                  • MORETTIGIAN
                    Capacitor detached from PCB – RTX 2070 Super Founders Edition
                    by MORETTIGIAN
                    Title:
                    Description:
                    During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                    I did not notice it detaching, so I am unsure of its original location on the PCB.
                    Procedure performed:
                    - Removed backplate
                    - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                    - Reapplied thermal compound
                    - Reassembled card
                    Observed behavior after reassembly:
                    - GPU powers on and operates normally under...
                    09-18-2025, 12:14 PM
                  • Prolog
                    RTX 3080 FE Identifying capacitor
                    by Prolog
                    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                    I hope these photos make it clear which component I am referring to:
                    (yes, the soldering is a bit botched from removing the blown one, I know)
                    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                    12-01-2024, 08:27 PM
                  • chth96
                    If I replace with inferior capacitor, Is it No harm to other IC components at all?
                    by chth96
                    I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                    Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                    It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                    So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                    I know that these capacitor will not last as long as nichicon capacitor...
                    12-22-2023, 04:34 AM
                  • chth96
                    How can I test non-polarized capacitor?
                    by chth96
                    I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                    I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                    And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                    I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                    06-02-2024, 07:31 PM
                  • chth96
                    Is it no harm to replace with capacitor without ripple current rating?
                    by chth96
                    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                    Rubycon YK DataSheet (b...
                    04-19-2024, 05:19 AM
