Replacing with Polymer Caps?
  • DaleCarr
    • Sep 2015
    • 14
    Just a quick question to see if its even possible or wise to do so. Can Electrolytic Caps be replaced by Polymer Caps. If so would the ratings be the same and is it even a wise idea?
    Dale
  • Stefan Payne
    • 1267
    Re: Replacing with Polymer Caps?
    It depends...
    What are you talking about?
    In PSU it can be a pretty bad idea due to too low ESR, on VRMs it may be possible, but you still may need some capacitance...
    So to really answer your question, we need more details of what things you mean...
    • DaleCarr
      • Sep 2015
      • 14
      Sorry about being so general. Right now I'm looking at a an MSI Motherboard that has bad caps on the 24pin power circuit. They are Electolytic caps and the rest of the board is Polymer caps. I didn't have any like caps to replace the bad ones but I do have some polymers on hand that might work if it was possible. I did find some more information last night on researching and it appears that some people have switched them before and you can cut the uF requirement in half by doing so. Of course this comes from sources I don't trust so I was looking here to get the experts opinion on doing so. I don't mind risking the board....its a cheap one at that. I don't do Fire and Smoke very well though so I'm just looking for advice.
      Dale
      • madscientist750
        Replacing electrolytic caps by solid caps on old motherboards
        by madscientist750
        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
        10-19-2025, 06:10 AM
      • Perry Babin
        How do organic polymer caps compare to liquid electrolytic for reliability
        by Perry Babin
        I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
        If not organic polymer, what would be the caps that could take the most abuse?
        08-18-2025, 04:04 PM
      • Noodneek
        Replacing all the caps on the BenQ SW2700pt's power board didn't help...
        by Noodneek
        My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
        I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
        08-30-2024, 12:52 PM
      • kotel studios
        TAGAN TG380-U01 PSU - 5v shorted after replacing caps
        by kotel studios
        Hi
        Recently I got this tagan tg380-u01 PSU with bad caps on 3.3v rail (the line was 2.5v no load!). Replaced them but no go, so I've replaced all of them, apart from some smaller ones and one under the secondary heatsink. Even that didn't help so I've replaced the others. All caps are known good ones.
        Powered it on and heard the breaker pop. Opened it up and saw some smaller caps shorted together. Fixed that up but still it trips breakers. Now I get 0ohms from 5v to GND. Secondary heatsink removed and still a short, even with the PWM IC board removed. All diodes on that...
        02-14-2025, 10:10 AM
        by momaka
        03-15-2023, 10:17 PM
