Testing a capacitor.
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    I have a capacitor which is rated at 220mfd and it has dropped to 210mfd.
    Can anyone tell me if I should change this capacitor?
    • 31288
    Re: Testing a capacitor.
    it's within spec.
    caps are rated at 20%+- the label.
    • SEAWOLF
      • Nov 2011
      • 177
      Originally posted by stj
      it's within spec.
      Thank you very much.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • genuineguy
        Microwave Oven Capacitor Testing
        by genuineguy
        Hello Experts
        Need help with my experiment to test a Capacitor from microwave oven
        Its a High voltage capacitor. 1mfd, 2100V AC.
        A DMM test across its terminals show infinite/open resistance.
        The capacitor has a 10Mohms shunt resistor internally.
        1. Connected 100w bulb in series to the capacitor. AC supply 230v connected. The bulb did not light up. This proves the capacitor is NOT shorted
        2. Connected capacitor in series with a diode and 10ohm, 10W resistor. Connected AC supply 230v. I was hoping DC voltage reading...
        09-21-2020, 12:56 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
