Electrolytic capacitor / SMD question!
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey guys ,
    Normally i post in the tv section but i have a few questions about those small smd capacitors and "normal" capacitors.
    First question is , whats the difference between the electrolytic capacitors with a black colour showing the negative side and a red colour?
    Also , on most power supply's in televisions you have the hot and cold side. On the cold side i have a few 1500uf/25v that i want to replace but sometimes i read about low esr. I normally just purchase capacitors with same value and higher voltage and don't pay any attention to low or high esr.
    Is it save to replace the 1500uf for example 1800/25v or 2200uf/50v?
    What can possibly go wrong? Can those caps pull down for example the 5VSTB?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Electrolytic capacitor / SMD question!
    These caps! They have weird values also , 120uf.
      • 31214
      red print may be polymer caps.
      on the output of psu's you should keep the voltage the same, keep the uf's the same or slightly higher, but use low esr caps only.
      unless you want the new ones destroyed pretty quickly.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Thanks for the reply!
        • Behemot
          • 4845
          • CZ
          You can go down with voltage as long as you know it's safe. They often use much higher voltage most likely because tho cheap craps can not actually withstand rated. So for example 25V cap on +12 V rail - pretty safe to use quality 16V caps in there. And increase the capacitance on the other hand.
          Capacities like 120 uF are actually common if caps are miniaturized but not so much to jump on the next more standardized capacity. Check those new Chemi-Con KYA, KYB, KZN, KZM, KZH series, they all have these 120, 39, 80, 270 uF etc.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Thanks for the reply , great info!
            • Stefan Payne
              • 1267
              ...or higher ripple current, lower impedance or they use 25V caps due to some other things we don't know about but the engineer thought about when specifying those for that...
              So I always would replace a 25V cap with at least a 25V cap, even on +12V rails...
              • Behemot
                • 4845
                • CZ
                Oh my…
                • mariushm
                  • May 2011
                  • 3799
                  In all likelihood, they used 100uF 25v capacitors because the diameter of 100uF 16v and 100uF 25v were the same, or they used 100uF 25v somewhere else on the board (so saving money by ordering more of same part and saving a roll on the chip shooter machine), or the cost for both versions was the same.
                  In the picture, it looks like there was some height constraint, so they used several capacitors of smaller capacitance in parallel to obtain the value needed.
                  • ttmi100x
                    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                    by ttmi100x
                    Greetings everyone,
                    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                    Upon closer inspection...
                    07-31-2024, 06:36 PM
                  • Gentian
                    Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
                    by Gentian
                    I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
                    09-27-2025, 11:03 PM
                  • MORETTIGIAN
                    Capacitor detached from PCB – RTX 2070 Super Founders Edition
                    by MORETTIGIAN
                    Title:
                    Description:
                    During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                    I did not notice it detaching, so I am unsure of its original location on the PCB.
                    Procedure performed:
                    - Removed backplate
                    - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                    - Reapplied thermal compound
                    - Reassembled card
                    Observed behavior after reassembly:
                    - GPU powers on and operates normally under...
                    09-18-2025, 12:14 PM
                  • cloudff7
                    Electrolytic capacitor leak in storage?
                    by cloudff7
                    there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
                    07-22-2024, 06:27 AM
                  • Loretto
                    Samsung SMPS BN44-00339A
                    by Loretto
                    this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
                    I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
                    I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
                    I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
                    03-29-2025, 08:30 AM
