caps question
  • mustwatchtv
    • Dec 2015
    caps question
    I just opened up my HD tv since it would just show the label in yellow and turn white for a second then back to yellow but on warm days it turns on fine anyway I found 5 bad caps bulging and black stuff on top I have changed caps in the past with kits they have for them but I just want to replace the bad ones,where can I buy these and what will work so many to choose from...they are 4x 10v 3300uf 105c (m) and 1x 10v 1000uf 105c(m)
    thanks for any info
    Re: caps question
    I USE PANASONIC FM or FR series from DIGIKEY, just check the dimension of the caps and get one that will fit into the board. I would at least replace ALL of them in the secondary side, bad caps can look normal.
    • mustwatchtv
      • Dec 2015
      Re: caps question
      thanks for the info..will replace all caps as you suggested
        • 31289
        Re: caps question
        for heat related symptoms dont overlook the really small ones!
        • nick3092
          Mid/late 80's Nichicon Yellow Caps
          by nick3092
          I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
          08-28-2022, 03:56 PM
          by momaka
          03-12-2025, 03:42 PM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • edith
          Caps and how to find one to replace
          by edith
          Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
          Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
          Thank you!
          06-11-2023, 05:00 PM
