Measuring capacity, ESR...
  • nManJofo
    • Jul 2006
    I've got plenty of capacitors I've desoldered from various mobos and PSUs, but I have no idea, how to measure their "condition". There are several RLC meters, but most of them can measure up to 100uf (+-). Is it different to measure electrolyte and any other capacitor? I cant afford any expensive multimeter, so a DIY solution would be great TY for help...
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Measuring capacity, ESR...
    i just toss em and install new.
    not worth the trouble to reuse.
    • blablaro
      Philips PSU (715G7350-P01-000-002S) No stand by light (0V)
      by blablaro
      This is the source from a Philips TV 43PUH6101 that suddenly stopped.
      I know it's the source since I have ~ 0 volts on outputs 12VA/16VA, 12V/16V, +3.5/+5V
      For the latest weeks I've been trying to figure out the problem with this. I've ordered all kind of mosfets, a capacity meter and other things to try to figure out the issue with this PSU. My wife thinks I'm crazi but I want to repair it
      Initially, when I started the testing with the multimeter on diode mode (220 V on):
      - discovered that was Q9101 shorted (or I shorted it)
      09-24-2025, 10:21 AM
    • chaoshusky
      Ongoing Acer Predator Triton 300 G53G LA-L191P woes
      by chaoshusky
      Well, this is the second laptop of the exact same model and spec to die on me, the first one lasting a month. Fortunately that was returnable, but apparently the seller lied to me about this one and had even had its warranty registered, so very much out of luck there and can't afford to lose £900..
      Anyway, it had been having issues for a while again with throttling, after fixing it briefly..almost like the heatsink is defective and slowly coming away! Worked great for a while, but started throttling on the GPU and throwing the odd blue screen, even when running in non turbo or...
      08-22-2023, 01:42 PM
    • quickname
      Cyberpower 1500AVR UPS repair
      by quickname
      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
      I decided to verify that the batteries were...
      11-12-2023, 09:57 AM
    • edugimeno
      How to correctly measure a mixed low&high current
      by edugimeno
      Hi there!
      Im trying to determine the consumtion rates of a module Im testing. Particularly it's a Decawave DWM1001 module, which is expected to use around nanoamps during normal state so a LiFePo4 battery should last months
      This module has peak spikes of around 100mA once a second, while the TX module is active, and then goes to sleep for the rest of the time (this is when the uA rates are expected)
      But I'm having issues to measure this current.
      1.-Using a multimeter. Obviously all I see is values jumping all the time, as this is not expected...
      11-15-2020, 03:51 PM
    • spleenharvester
      Reverse engineering of 18650 4-channel tester
      by spleenharvester
      Hi friends
      I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
      05-04-2025, 02:43 AM
