Asrock G41M-VS3 is using SAMXON caps
  • liukuohao
    • Oct 2013
    • 63
    • Malaysia
    Hi All,
    I would like to know whether my Asrock G41M-VS3 motherboard
    http://www.asrock.com/mb/Intel/G41M-VS3/
    is using bad capacitors or not.
    It has a lot of the SAMXON caps which is rated as 1000uf 6.3v.
    I could not find this SAMXON caps from the bad caps list.
    So, I suspect they are not the best and may be not the worst caps.
    Heat is a major concern with me, since I am living in a hot and humid
    country that cannot afford to turn ON air condition all the time 24/7
    just to cool off PC running non-stop as NAS server.
    Any advice will be most appreciated.
    Thank you.
  • MassBoost
    • May 2015
    • 9
    • US
    Re: Asrock G41M-VS3 is using SAMXON caps
    If you'd look at what Topcat has to sell, you might notice that he sells Samxon capacitors.
    https://www.badcaps.net/pages.php?vid=24
    In that being said, I don't think you should have any concerns as they wouldn't sell any capacitors of that nature if they were inferior.
    Topcat is quoted as calling them as "'middle grade'", just so you know.
    • liukuohao
      • Oct 2013
      • 63
      • Malaysia
      OK got it, MassBoost, thanks for the reply.
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • BigTroll
        Asrock DeskMeet return of the bad caps
        by BigTroll
        I have had good luck with asrock products but with that said I ordered a DeskMeet X300 to use up some other components I had laying around Ryzen 3600 GTX 1060. it comes with a 500w power supply built by CWT.
        I thought CWT would use good components but no the primary cap was ChengX and the secondary had lots of chengx and JunFu caps. hope it lasts awhile. I do have a 450w SFX silverstone with teapos on the secondary I could replace it with.
        10-14-2023, 11:57 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
