Hv In Place Of Kzg ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Hi all just got this asus motherboard in today and noticed that someone has professionally replaced some caps on the output of the cpu vrm. The caps are 1000uf 16v 10mm Di nichicon Hv, looking at images of this board the original caps used in the replaced ones are ucc kzg. Will the Hv work inplace of the Kzg or shall I order some Mbz's ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Hv In Place Of Kzg ?
    Boost
    • mockingbird
      • Dec 2008
      • 5484
      Assuming the cap is 8x20mm, the specs are as follows:
      KZG:
      Impedance 0.021 Ripple 1870
      HV:
      Impedance 0.031 Ripple 1550
      So the HV are slightly inferior, but they might work here (VRM high), especially if your PSU isn't too noisy.
      On Asus boards these caps are almost always interchangeable with 16V 270uF (Or more) polymer caps.
      The question is, did he use real HV caps or eBay knockoffs?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        KZG:
        HV:
        Thanks for the reply Mockingbird, they look real when it comes to the sleeve, I might desolder one and get a look at the bung just to be sure.
          • 31067
          MBZ is discontinued.
          so while i would use ones i had, i wouldnt buy any.
          if you recap, use poly's
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ok thanks for the info mate, will do. They are genuine btw so guess I could keep them.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Installed 330uf fp polly caps works great been using the board almost daily not a single glitch
                by momaka
                03-12-2025, 03:42 PM
              • tony359
                Best tool to place electrolytic SMD caps on a board
                by tony359
                HI all,
                I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                01-28-2024, 06:23 AM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
