samxon GE caps
  • leekh
    • Jan 2007
    • 24
    samxon GE caps
    hi! i just received a new P4 S478 mobo. it has 2 Rubycon MBZ series on the VRM input, one whole row of 6 Samxon GE 2200uF 6.3V on the VRM output. the rest of the board is populated wif Samxon GF 470uF 16V at the DIMM slots, AGP slot and the ATX connectors. the smaller ones w/o vents are of United, 100uF 25V. does the Samxon GE caps good or not since they are nt discussed in tis forum?
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    Re: samxon GE caps
    I never seen any GE caps on hardwares in market. I knew Samxon have GE series, but i am not interest to source it. The reason is the pricing is not much different with GD, GC and GA. Why need GE?
    Besides, The color of GE series are silver, not different with GD, GC and GA. By this reason, i guess the formula of eletrolytic should be not same as GD, GC and GA(golden).
    May be i will get some samples of GE series for reference, because i never seen the caps with silver printing letters, quite interest
    Do you have any photos of Samxon GE? If yes, please post here, thanks.
    My SAMXON Capacitors Database HERE!!
    X-CON is a new brand for SAMXON's Polymer Capacitors.
    • leekh
      • Jan 2007
      • 24
      Re: samxon GE caps
      here they are!!!
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
