Replacing Capacitors on a Samsung LNS4696D power board
  • crookedmosquito
    • Feb 2015
    I have read a couple threads and believe my issue is bad capacitors but I am not sure on what to get. The ones on the board are CapXon and these are the values:
    5 - 1000uf 10v GL 105C
    8 - 47uf 50v KM 105C
    5 - 10uf 50v KM 105C
    4 - 1000uf 25v KM 105C
    If there is more info needed let me know.
    Thanks for the assistance
    by sam_sam_sam
    After all of...
    07-13-2024, 08:14 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • ohren
    by ohren
    09-08-2023, 05:24 PM
  • C152Heavy
    by C152Heavy
    Summary for TL-DR readers:
    • VCC pin (18) of PFC...
    01-11-2023, 02:53 PM
  • MacGyver's paperclip
    what to check before replacing hybrid MOSFET/controller IC on SAMSUNG TV power board
    by MacGyver's paperclip
    TLDNR; Have an old SAMSUNG TV with blown hybrid MOSFET/controller IC on power board to be replaced; replaced blown main capacitor on same power board several years ago successfully, and TV has been working fine since until this IC popped all of a sudden. Want to know what if anything to check on board to make sure before replacing and testing with new IC. Have 2 new matching ICs, DIP socket to make removal/replacement easier, a whole other known-good power board with which to compare, if necessary.
    07-01-2023, 12:12 PM
