Lytic voltage for replacement
  • Electronicjoe
    • Dec 2014
    • 11
    I read somewhere that recapping with a higher voltage will not always succeed because the new cap may not "form" properly if it is rated much higher than the voltage it sees. Is this true? Can I use a 25 volt electrolytic in place of 10 volt?
    Electronicjoe
  • mockingbird
    • Dec 2008
    • 5484
    Re: Lytic voltage for replacement
    Nonsense. You can always use a higher voltage aluminum electrolytic cap. What does happen is that the etching in the foil conforms to the lower voltage if you run it for a while, so you can't use that cap in the future for its rated voltage.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Electronicjoe
      yeah, if they have been sitting for 50 years like in the tube radios i work on. then otherwise, no.
      have you been on the audiokarma site? that sounds like (mis)info you hear there.
      Follow the white rabbit.
        master hoarder
        • May 2008
        • 12175
        Actually, you can. However, you must "reform" the cap first.
        First find a power supply that has an output voltage as close as possible to the capacitor's rated voltage (but not higher). Then using a 1 KOhm resistor or higher (10k is a little safer, but the process is slower), hook the capacitor in series with the resistor and connect to the power supply. Let it sit like that for a while. In my experience, 1 hour is more than enough. Some caps will reform (adequately, but not fully) within 5-10 minutes.
        I often do this when I re-use motherboard capacitors (when I remember, that is ).
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • tvguy12012012120
          Samsung UN55NU6900F Standyby voltage is 1V higher than expected, is this a problem?
          by tvguy12012012120
          This is the zombie UN55NU6900F I wrote about in this original post.
          It originally was completely dead with no standby voltage. After some poking around, I found the solder at RM819 (see pictures) failed. I removed it from the board, it tested fine, resoldered it, and now the TV works.
          The expected standby voltage at the reference pin is specified to be 11.8V but it's reading 12.8V. Couple questions:
          1. What could cause the standby voltage to be 1V higher than expected
          2. Is this a problem
          3. Could it have led to the failure at RM819, or was that...
          02-12-2025, 11:22 AM
        • UserXP
          Transformer producing higher voltage than rated
          by UserXP
          Hello, people.
          i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
          So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
          09-02-2025, 12:42 AM
        • Macroman
          Help...Replacement of LDO voltage regulator
          by Macroman
          I sure could use some help with replacement of a LDO voltage regulator...any help would be appreciated.
          I have a camera flash with twin heads that in the late hours of the evening while shooting macro photos of insects...I put a couple batteries in backwards and it blew a 47uf capacitor, (replaced already), it messed up a 6 pin 2 position switch (replaced already) and also a 7536-1 LDO voltage regulator, 100mA, 3.6v OUTPUT, ±3%, SOT-89.
          Data sheet here-- HT7536-1 LDO voltage regulator, 100mA, 3.6v OUTPUT, ±3%, SOT-89
          Input power source on this...
          02-27-2022, 07:48 PM
        • aurgathor
          Recommended replacement cap & voltage
          by aurgathor
          I have an older SFF Dell (GX620) that I want to turn into a router, but it has a few *really bad* looking electrolytic caps (4x 2200uF 6.3V & 1x 1800uF 6.3V) that need to be replaced first.
          Questions:
          1. What are some the recommended caps for these values? (I will probably order from digikey)
          2. Looks to me there is enough space for slightly bigger caps -- would I gain anything with respect to longevity by using 10V caps instead of 6.3V caps? (I guess I probably need to look at the current voltage with a scope since I do not know the nominal voltage of that r...
          08-25-2024, 05:14 PM
