How to buy the correct replacement capacitor ?
  • ftechno
    • 9
    • france
    hi i want replace ost rlx 470uf 16v with 470uf 16v SANYO SEPC Aluminum solid Capacitor for hp desktop motherboard dc7800 but the difference is in Rated ripple current (mArms). is it possible?
    if there is any advice you welcome
    • 31289
    Re: How to buy the correct replacement capacitor ?
    ost
    10x13mm
    0.038 ohms
    1253ma
    sano
    10x13mm
    0.010 ohms
    6100 ma
    well it's overkill, but it will probably work!!!
    • ftechno
      • 9
      • france
      Originally posted by stj
      ost
      10x13mm
      0.038 ohms
      1253ma
      sano
      10x13mm
      0.010 ohms
      6100 ma
      thank you "overkill" its can damage my motherboard
      • ftechno
        • 9
        • france
        can you segest me some good caps to replace ost rlx 470uf 16v
        thank you
        • ftechno
          • 9
          • france
          can you suggest some good replacement for this ost rlx 470uf 16v capacitor
          thank you
          • ftechno
            • 9
            • france
            sorry for the repetition
              • 31289
              the sepc wont do any damage, i just meant it's very very over doing it!
              rubycon mcz look good, they are a bit smaller but the ma and esr look good.
              • MORETTIGIAN
                Capacitor detached from PCB – RTX 2070 Super Founders Edition
                by MORETTIGIAN
                Title:
                Description:
                During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                I did not notice it detaching, so I am unsure of its original location on the PCB.
                Procedure performed:
                - Removed backplate
                - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                - Reapplied thermal compound
                - Reassembled card
                Observed behavior after reassembly:
                - GPU powers on and operates normally under...
                09-18-2025, 12:14 PM
              • artvandalai
                Where can I get compatible capacitor for replacement?
                by artvandalai
                Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
                12-28-2024, 10:15 AM
              • r2digital
                klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                by r2digital
                I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                04-18-2024, 03:50 PM
              • rwkish
                Discontinued Capacitor looking for Replacement
                by rwkish
                Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
                08-18-2024, 06:54 PM
              • Hylax
                Replacement capacitor options please?
                by Hylax
                Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
                08-09-2024, 11:25 PM
