Hello, I just want to ask how to check if non polarized and polarized smd capacitor is shorted on/off board.
How to test smd polarized and non polarized capacitor if shorted?
by chth96I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...-
by modtoolHi to all,
the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts... -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
Assuming...7 Photos -
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos - Loading...
