I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions 10/25/5, but they are only located at 12.5 diameter. I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 and they are next to the secondary circuit for 5v and 3.3.I have two KMG 50v10uf, one of which I think is at the 5VSB input (it stands right next to the two SNAP-in KMR 400v680uf) ), and the other under the 5VSB transformer with dimensions 5/13/3.5 and again raised to fit in pitch 5 on the board. I have another KMQ 50v68uf (I think it acts as a reservoir for the IC chip) with dimensions 7/13/3.5 and it is also raised for pitch 5.I have one KMG 50v4.7uf with dimensions 5/11 or 12/2.5, which is also raised and fits into pitch 5 on the board, I think this one is for the logic board. One KMG 16v100uf on the fan board with dimensions 5/11 or 12/2.5, which is also raised for pitch 3.5. And finally there are 11 Capxon SY 16v330uf for filtration to the connectors on the output board.The problem is that the large 3300uf and 2200uf are not available in the sizes that are in the power supply, but are only available at 12.5, as well as other brands Rubycon and Nichicon, some of their low impedance, high ripple series are also available at 12.5. KMG also seems to be no longer produced, and to be honest, I want to put ones with a long life, even though they are for unpretentious places. I also can't find this KMQ 50V68uf,but for it as far as I understand, I can use 50v100uf but I wish it had a long life too.I've been reading and comparing with other brands and series for a week, but I've fallen down the rabbit hole and need your professional help.I'm an electronics enthusiast and I'm still learning. My soldering skills are average, but I think if I'm careful I'll be able to handle it without any damage.
Replacing capacitors in Evga PSU
Tags: None
I don't know much about EVGA, but I know for damn sure you should avoid modern Chemi-Con. They're not Japanese anymore. They're actually owned by KEMET now, which is a European company. -
If I were you and recapping this unit, I would go for Rubycon ZLH/ZLJ, Nichicon HE, or Panasonic FR/FM, and for the primaries: Panasonic TS-ED/TS-HA, Nichicon GU/LGU, or Rubycon MXR.Comment
by karatzdiHello,
I know some might say... just buy another one. Sell it as parts..!
So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
Spent some time downloading the Service...-
06-11-2024, 08:38 AM -
by coinwizxThe power supply is 2020 Corsair HX1200 modular power supply.
Cause of damage: I connected EVGA molex cable to the Sata port and test it with a ATX tester. Since the pin out on the EVGA is wrong, result in the 12V pin shorted to the 5V pin, in the 12V back-feeded to the 5v port.
Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then try to re power up.... -
by coinwizxThe power supply is 2024 newest version of NZXT C850 modular power supply.
Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then... -
by ReintarFirst of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...08-30-2024, 06:13 AM -
by onix331Asking here as a last ditch effort:
GPU: EVGA RTX2070 Black Edition XC Gaming
A few weeks ago i noticed a burning electronics smell in my room, after a bit of confusion i realized that the RGB LED light of my GPU was out. Weird.
I didn't think much of it until i tried to look at the power usage in HWinfo, i then noticed that the entry "GPU Power (Total)" was gone entirely, it would also not boost above 1410Mhz.
Looking further i noticed that "Performance Limit - Utilization" was always at "Yes". The card did perform mostly...05-27-2024, 08:34 AM - Loading...
