Current project is almost all Nichicon VX capacitors (20%) which appear to be discontinued. Any recommendations for a high quality replacement? Thanks
Nichicon VX replacement
by DaveHarryHi group,
I am looking for a replacement for Nichicon PLV1J220MCL1TD (22uF, 63V, Conductive Poymer Aluminum Solid Electrolytic, 8x9 but we can go up to 8x11).
While searching, I found some APAQ and ELITE replacements that would fit on our products (APAQ ARHA series and ELITE UGT and UPD series).
How good are these brand/series and what other alternative would you recommend? I've searched the big name already and didn't find an equivalent.
Thanks!-
Channel: General Capacitor Questions & Issues
05-27-2024, 08:08 AM -
by rwkishCapacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
by sam_sam_samI need to order some because my parts bin is getting very low on this value
Thanks to anyone that can help
Dig key is out of stock and so is Mouser Electronics is also out of stock as well
I found some from a eBay seller that shows the box that 3000 of them are boxed in I think I should be alright buying them from this seller-
by KermitJReceived a Insignia NS-24E40SNA14 24" Class LED HDTV LCD HD TV because the power supply got lost in moving.
Fortunately there are a number of replacements for it. They include
Newegg AC DC Adapter for Insignia NS-24E40SNA14 24 Class LED HDTV LCD HD TV Power Cord https://www.newegg.com/p/14R-02MY-001N9
Amazon UpBright New Global 12V AC/DC Adapter Replacement for Insignia NS-24E40SNA14 24" Class LED HDTV LCD HD TV 12VDC 3000mA 12.0V 3.0A Power Supply Cord Cable PS Charger Mains PSU https://www.amazon.com/UpBright-Adap...4E40SNA14-Char... -
by Almighty1Greetings everyone:
I have a Polycom formerly Obihai Obi202 VoIP Adapter which has the following 2 capacitors:
1 x ChengX 100uF 25V 0.25"Wx0.3125"H
1 x YST 10uF 50V 0.1875"Wx0.4375"H
What are suitable replacements that are long life and rated 105C or higher? Am I correct that the uF has to match but the voltage can be the same or higher? Are there any advantages and disadvantages if it's higher than the original voltage?
Thanks!-
- Loading...
