Slow and fast venting caps
  • Tom41
    • Oct 2005
    • 336
    • England
    What exactly is it that causes a cap to vent slow or fast? Most vented caps I've seen on motherboards have a domed top, and sometimes a small layer or mound of electrolyte on the top. That would seem to suggest that the cap failed gradually, slowly exuding the electrolyte after doming up.
    I also tried connecting a cap up to a DC supply, set to twice its rated voltage at reverse polarity. I expected it to dome up slowly and start oozing electrolyte - but imagine my shock when the cap literally exploded with a noise like a gunshot, and a cloud of smoke! That must have been a 'fast' vent.
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • Sparky
    High voltage
    • Jan 2007
    • 234
    Re: Slow and fast venting caps
    Can we say boom?
    When a cap on a mobo vents it is still usually at its rated voltage at the proper polarity. Reversing polarity is a good way to vent one fast, and then doubling the voltage, well, you saw what happened
    • PeteS in CA
      • Aug 2005
      • 3579
      • USA, Unsure of Planet
      Venting is due to hydrogen gas released when the aluminum oxide layer is "formed". This could happen if the existing layer is too thin for the applied voltage - either an over-voltage condition or the existing layer has been attacked by the electrolyte. In the case of mobo caps, this forming is slow, as is the build-up of gas (and internal pressure). If you apply a significant over-voltage or a reverse voltage, the forming and gas production is rapid ... until it makes a loud noise.
      PeteS in CA
      • bgavin
        • Jan 2007
        • 1355
        Similar to a Noise Emitting Diode (NED) when driven over-voltage.
        • gastorgrab
          • May 2007
          • 320
          Yeah, i got an uncle who caught some shrapnel back in 'Nam when a grenade 'vented' nearby.
          • Caimano
            hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
            by Caimano
            MB G7AD-2G DAG7ADMB8D0 REV D
            Processor i5 8265U
            AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
            Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
            Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
            02-06-2024, 10:14 AM
          • socketa
            Bestec ATX0300F5WA - fast,or slow blow, fuse?
            by socketa
            I bought a dead motherboard, and connected it to this PSU,
            Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
            So now i truly got a bang for my bucks, and something else to try and fix.
            The fuse was blowen, and the top was blowen off of a TNY276PN chip
            The glass fuse didn't have any marking to say if it was fast or slow blow
            So i checked the marking on the PCB thinking that that would tell me,
            but it 's got a T/F8A printed on the board
            So should i get a fast blow fuse, or should...
            05-17-2022, 01:22 AM
          • joblo37pam
            Sharp LC-80LE844U Blinks 2 slow, 5 fast
            by joblo37pam
            It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
            The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
            10-26-2023, 02:17 PM
          • Comp_Pro
            820-01949 Running Slow Fast Fan ASD Software Download?
            by Comp_Pro
            Hello all,
            I'm trying to repair this A2251 macbook pro. Board is 820-01949. The original issue was liquid damage which all cleaned up well and the board was not heavily damaged. Unfortunately after liquid damage cleaning the computer is running extremely slow and the fan is running at full speed. Even the cursor is lagging. Because of this I can't use the built in hardware diagnostic to give me a clue as to what is happening. Does anyone know if Apple Service Diagnostic software is available for this model? Any other clues which could help me out? Seems to me there is an issue with...
            11-30-2023, 05:33 PM
          • Stephen
            A1990 MacBook Pro 15" Turning on, loads then boot loops, fan spin slow and then fast
            by Stephen
            Got a MacBook Pro 15" A1990 with a board issue, The board turns on, I did a DFU revive to see if it needed a firmware patch, that was successful, however the board just keeps boot looping and turning off and on very quickly. Obviously the DATA Is there, but it wont even launch into recovery, it will just die and turn back on with Apple logo, once it gets really hot it dies, if the laptop sits for the day and is cool, it will turn on then get hot within 1 min then die and turn itself on and repeat. Once it does that it turns itself on and off repeatedly in seconds. I put a thermal camera...
            10-04-2024, 02:50 PM
