I think i found some caps
  • Shimen
    • Jul 2007
    • 16
    Hi guys I promised some pics of my MOBO. So here they are. I put the bad cap back into my comp and put the basics in it so i can post pics and do my order from my home. The ones in the board are 1200uf 6.3v choyo caps a total of 10 of them. the ones i want to get are nichicon 1500uf 6.3v. part # UPW0J152MPD
    Everything is same except for UF value but was told i can bump that up a little and it will not affect anything. Nichicon makes another #UPM0J122MPD but there is a 91 day lead time on it and also a minimum order of 200 it matches exactly but i dont need that many. So what are your guys thoughts. I want to order them today so if you have time give a shout back thanks.
  • Shimen
    • Jul 2007
    • 16
    Re: I think i found some caps
    Oh looking around on Mouser.com i found something else Nichicon makes a 6.3v 1200uf in the PW series specs.
    UPW0J122MPD6 : 1200uf : 0.068Impedence : 1050ripple mA rms: 10D x 16L compared to the one i mentioned in the first post
    UPW0J152MPD : 1500uf : 0.052Impedence : 1220ripple mA rms : 10D x 20L
    The 1200uf is 3mm shorter than the ones i have on the board. Lead spacing is same on both. Just thought i would through a bit more info at you guys.
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      The PW series is a better series than the PM series. Look into Digi-Key. They carry Nichicon, Panasonic and United Chemicon (UCC). Specifically, I suggest looking at the Panasonic FM series and UCC's KZE series in that order of preference. D-K carries the PWs, but I think FM or KZE will be more suitable for a MB application.
      PeteS in CA
      • Shimen
        • Jul 2007
        • 16
        Alright i took your advice and ordered the Panasonic FM Series Caps. 15 in total. And i should be getting them around tues. Thanks for your help man.
        • DrewPhillips
          Capacitor Diarrhea - Nichicon PL Series
          by DrewPhillips
          Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
          The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
          03-02-2025, 10:18 PM
        • nick3092
          Mid/late 80's Nichicon Yellow Caps
          by nick3092
          I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
          08-28-2022, 03:56 PM
        • chth96
          Is there datasheet for nichicon LXJ series?
          by chth96
          I want to calculate capacitor ESR referring to below guide.
          https://forum.digikey.com/t/calculat...-from-tan/2633
          I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
          I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
          Is there anyone who still has old nichicon datasheet which has information of LXJ series?
          11-20-2022, 08:11 AM
        • chth96
          Is there any datasheet for nichicon RT(M) series?
          by chth96
          A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
          https://www.badcaps.net/forum/troubl...e-been-blew-up
          and I finally fixed​ this retro game console by soldering varistor and glass fuse.
          But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
          I have spare console...
          11-28-2023, 03:36 AM
        • Jim P
          Nichicon VX replacement
          by Jim P
          Current project is almost all Nichicon VX capacitors (20%) which appear to be discontinued. Any recommendations for a high quality replacement? Thanks
          10-27-2025, 08:29 PM
