Are any capacitors produced outside the Asia-Pacific region?
  • athenian200
    • Jul 2014
    • 10
    It just occurred to me while searching for various brands of capacitors and checking where they're made, that these components all come from more or less a single region of the world. Somewhere in China, Japan, Taiwan, or Korea, which are all fairly close together.
    It got me wondering about supply vulnerabilities. I mean, suppose some country like North Korea or China started conquering their neighbors like Taiwan, SK, and Japan, and we ended up in a protracted war. Where would capacitors and small electronic components come from? Is there a backup plan?
    It's not that I don't think they're doing a good job making them, it just really seems like we have all of our eggs in one basket. I would think we would have at least one backup supplier with facilities elsewhere.
    So, hypothetically, does anyone know if any companies manufacture them in South America, Africa, North America, Europe, etc? Or would it just be impossible to produce/repair any complex electronics in that scenario?
  • Destroyer-Br
    [HELP] ME Region Cleaning Request – Motherboard GK5MP5X 1.0
    by Destroyer-Br
    I’m working on a laptop in which I replaced the PCH, but I’m unable to clean or rebuild the Intel ME region using FIT.
    When I load my dump into FIT, it only shows the Intel(R) ME Kernel section. The full ME region structure does not appear.
    If I manually replace the ME region inside the decomp folder and try to build the image, FIT does generate an outimage.bin, but the file is corrupted.
    After flashing it, the board does not power on — no signs of life.
    I’ve identified that the issue happens because my original dump does not contain a complete or valid ME...
    11-23-2025, 02:48 PM
  • tom3k
    Dell Precision 5540. Need clean ME Region
    by tom3k
    Laptop: Dell Precision 5540
    MB: LA-H331P Rev: 1.0(A00)
    Hi.
    I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
    After extracting my BIOS in FIT the ME Region size is 7565 KB.
    However the ME Region files I fouud online are 11688 KB in size.
    Can someone help me find he correct clean ME Region?
    Thanks!
    Code:
    ║ Family │ CSE ME ║
    06-28-2025, 12:34 PM
  • Instafixx
    Macbook A2179 820-01958
    by Instafixx
    Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
    The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
    I checked the Power Sequences below and found this -
    Once a valid external power source (Charger or battery) is connected, the following rails will come online.
    PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
    PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
    05-20-2023, 05:19 AM
  • slybunda
    AA and AAA battery charger capacitors?
    by slybunda
    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
    it has inside:
    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
    2 x 470uf 16v LZ105c branded as G.Luxon
    not heard of these brands are they any good?
    iv attached photos of the charger and the board inside for an idea on the type of...
    12-24-2023, 04:41 AM
  • Adenitz
    Clean ME region - a bit of theory
    by Adenitz
    Hello laptop repair experts,
    can someone plese, help me understand the significance of cleaning ME region in a BIOS dump file?
    I know that Manegement Engine (ME) data is part of BIOS/UEFI firmware. I know that it contains some HW specific data for the particular laptop.
    What I don't know, why do I need to clean ME region if I try BIOS dump file from another laptop (of course same type and model). I'm not sure if this is only because of the serial number (not sure if that is stored in ME region at all).
    Recently, I had a two cases where laptops (one is Lenovo Idepad...
    10-21-2023, 04:44 AM
