Cpu Temp Stay At 40○c
  • wan901
    • Jun 2007
    • 69
    HaY GuYS ....I lIke To AsK AbOut ThIs MoTthErBoArD.... MSI 6547 board... Before it cannot post , i saw some bluking caps..and i change it , now it can pos but when i look at the CPU tempurature it stays at 40"C and changing... When i want to performed intallation windows it just like hang ...booting very slow....i change the part 2200uf 6.3v caps only but not the 1500uf 16v...
    Is the caps of 1600uF 16v? or Any other electronics problem ?
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Cpu Temp Stay At 40○c
    Have do done a CMOS clear after the cap replacement? If not try it and apply some very conservative settings at the BIOS setup (e.g. load the default values, safe and reboot, after that apply your particular settings).
    • tmcw
      Drying Oven - Preset Temp Fail
      by tmcw
      Here's an unusual one...
      This is a Gallenkamp oven, used in a laboratory space, goes up to 220 Celcius, but is usually maintained at about 115 Celcius. Used for drying glassware, molecular sieves, and so on. Oven is in excess of 20 years old.
      It heats up fine, there is an orange light on the front that indicates that the unit is heating, and when it reaches the preset temp, the orange light goes out. All good so far.
      However, after the preset temp is reached, the temperature continues to rise, power to the heating elements isn't cut off.
      01-21-2021, 03:11 AM
    • foshland
      MSI MAG Z390 Tomahawk BIOS temp, allways at 0ºC and CPU goes protection 800Mhz
      by foshland
      Hi to all, my motherboard (bought second hand as faulty, but now working after cleaning the ram slots) have a strange failure that shows 0 Celsius degrees in BIOS, because of that, the CPU goes to protection mode and gets stuck at 800Mhz.
      Since its a 8-9 Intel generation, I know the CPU temp is the hottest temp of the cores (as i have read in intels documentation) so its not a diode or sensor on the board.
      External temperature (motherboard temp) is working OK, 27ºC more or less
      In windows, all the software I have tested shows correct the Core temps
      12-16-2023, 09:08 PM
    • mosfetratus
      concerning gtx675m vram temp
      by mosfetratus
      Is 98C vram temp are safe? Less demanding games goes 80ish.
      Funny thing, there were old non stock thermal pads very botched, so i replaced them. After, temperatures remained the same, but performance (fps) improved significantly. With both thermal pad application GPU core temp was similar.
      furmark goes about 104C, amperage keeps rising so do temps.
      01-30-2025, 08:41 AM
    • Malcolma172
      Philips 42pfl6008s/12 red led comes on for a second and then goes away but 3.49v stay active
      by Malcolma172
      I was trying to repair my tv wich previously had a blinking red led 2 times and it kept going. After shorting the sdm the blinking led changed 5 slow blinks and 3 fast ones wich in the service manual meant error 53 / the fusion chip.
      After I heated the fusion chip with a hairdryer for 5 minutes it started working perfectly but after a day it stopped this time no led blinks even in sdm mode.
      After probing the psu I have 3.49v and for 1 second I have at least 2 12.3v lines active the fusion chip gets warm in that second the led turns on and then the 12v lines start losing power...
      07-23-2025, 01:20 PM
    • Hannibal_Hector
      Samsung UN39EH5003FXZA won't stay powered off
      by Hannibal_Hector
      Purchased a broken Samsung UN39EH5003FXZA (Version CD01) to have fun fixing. When I first acquired it, I did not connect any video signals and only plugged it into the wall. The unit booted and showed the “no signal” window and I could navigate all menus and change sources. I unplugged it, connected my over-the-air antenna to the coax, powered it on, got the unit to scan the HDTV channels, and I think then the TV self-shutdown with the melody. When I powered back up (melody), it would show the channel selected on the OSD and after a couple of seconds, it self-shutdown...
      03-02-2021, 07:57 PM
