help finding a mkp replacement
  • omgitdrifty
    • Aug 2024
    • 16
    Hi guys so have a mkp 0.47uf 310v capacitor.
    as you can see in the image. I want to find a replacement and not get the wrong one, can you help please Thanks
    I through this one would be ok?
    https://www.ebay.co.uk/itm/125432079...oAAOSwp2dnfV2E
  • redwire
    • Dec 2010
    • 3912
    You need to measure the pin spacing, they come in standard increments. It can come in either 22.5mm or bigger 27.5mm for that part.
    The logo "IC" is Illinois Capacitor/CDE, MKP 310VAC 0.47uF X2 safety cap. 474MKP275KB is 22.5mm and 26*16.5*7.5mm box. MKP Series X2 PP datasheet
    Need to confirm the dimensions.
    The Kemet R463N347050M1K is LS=22.5mm, size 26.5*16*7mm. Would be OK as a replacement.
