VP6 not powering up
  • fpz
    • Jun 2007
    VP6 not powering up
    I have the following problem with my VP6 board: it does not power up at all when I press the power button (I was able to power it on after many many tries before, but it's becoming more and more difficult to turn it on). I also have BSOD from time to time (not too often). It also freezes from time to time (not often, but it happens).
    Do you think this can be caused by bad caps?
    I had a look at the board but I can't see any bad caps (no bulging or disfigurement, etc.).
    Thanks.
  • starfury1
    • May 2006
    • 1256
    Re: VP6 not powering up
    The other possibility is the PSU Caps
    what brand is it? how long has it been running
    The symptoms are those that would happen with badcaps....that does not mean they the only cause.
    Just a likely cause depending on brand and when the MB was made.
    you say its been progressively getting worse which does again support badcaps as being the culprit.
    Badcaps can if left to long cause other damage
    there are a few who are familiar with this MB so they will probably post on it
    one post I found mention Teapo's know bad caps bit strange thought if this is a dual cpu job?
    Its a well regarded board on this forum by the quick search I did
    HTH cheers and Welcome
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      if it has teapo or jackcon caps on it, dont even bother looking at them, just recap it. teapos are notorious for failing without showing a single physical sign of failure.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        +1
        i can show you a pile of junkcons from 4 vp6 i just did.not bulging/leaking but at 15 ohms esr they are as good as open.
        when the mobo does not power up do you get a fan twitch?
        a sick psu can cause this.
        • starfury1
          • May 2006
          • 1256
          Thanks guys I had a feeling you 2 would pipe up
          so these are badcap MB's but apart from that good ones
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            yes they are.recap and use.
            repair not complete without tc's modded bios though.
            • Green Probe
              Recapping a Denon AVR X6400h SMPS
              by Green Probe
              (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
              Disclaimer: I'm an amateur hobbyist and will get things wrong.
              Always use caution when working around mains power and high voltage capacitors!
              Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
              SYMPTOMS:
              -No display...
              07-18-2025, 03:36 PM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
              by momaka
              03-15-2023, 10:17 PM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • madscientist750
              Replacing electrolytic caps by solid caps on old motherboards
              by madscientist750
              I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
              I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
              I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
              10-19-2025, 06:10 AM
