NV-V8000 vcr caps change
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 332
    • D12
    Originally posted by stj
    got a link for the manual?
    I put link in Post #3
    Code:
    https://mega.nz/file/49QSnJbB#dKmndz_Y1U8iJnWTC5r8HlwbxGtFSJ8vkc-ju2a3OCQ
      • 31086
      i have no idea what i'm looking for,
      which pcb and what else can you say?
      • Thermaltake
        Brain badcap
        • Aug 2015
        • 332
        • D12
        In manual, Page 127 MBO VEP07336 - C3768 position.
          • 31086
          c3768
          220uf 16v
          it's in the schematic on 126, a 12.1v to 9v regulator circuit
          • Thermaltake
            Brain badcap
            • Aug 2015
            • 332
            • D12
            c3768
            220uf 16v
            Damn I am blind.... thanks!
            Low esr can go there ? And on that board when I replace those big caps, can all be low esr ?
            • Thermaltake
              Brain badcap
              • Aug 2015
              • 332
              • D12
              #26
              I am curious because I am going to buy them, but not sure if they should be normal or low esr...
                • 31086
                low esr is fine - and longer lasting
                • Thermaltake
                  Brain badcap
                  • Aug 2015
                  • 332
                  • D12
                  #28
                  Thanks!
                  I calculated around 44 capacitors will be changed on vcr hope everything went well. I even corrected some factory faults on it, and now only cap changing is left. I'll let you know, and post some pictures if that's ok.
                  • Thermaltake
                    Brain badcap
                    • Aug 2015
                    • 332
                    • D12
                    #29
                    Update on my V8000.
                    Around 50 electrolytic capacitors​ were replaced plus some smd electrolytic caps too. Corrected a lot of bad solder on various boards in video section, they were the reason why front inputs were not working. Now everything is working as it should.
                      • 31086
                      what are you doing about rubber stuff like idlers and pinch rollers?
                      • Thermaltake
                        Brain badcap
                        • Aug 2015
                        • 332
                        • D12
                        #31
                        On V8000 there are not many rubber stuff, it's mostly mechanic. One belt which is okay I inspect it, and pinch roller which is also like new. I just refresh them a little.
                        But on my other VCRs I replace old rubbers with new one if they are broken or worn out.
                          by momaka
                          03-12-2025, 03:42 PM
                        • eryjus
                          by eryjus
                          05-10-2023, 11:21 AM
                        • Paxman_Swede
                          by Paxman_Swede
                          Hello!
                          01-14-2025, 09:51 AM
                        • captain150
                          by captain150
                          03-16-2025, 07:34 PM
                        • Foetuss
                          Gigabyte GA-6OXT :: caps question
                          by Foetuss
                          Good evening
                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                          But I was also suprised about the bigger boys, which are 330µF 25V.
                          Could it be they used 25V caps because they were cheaper / available at that time?...
                          02-11-2025, 12:22 PM
