Unknown Capacitor in Proton Receiver
  • Compgeke
    • Feb 2014
    • 524
    I picked this thing up for a whopping nothing today, although I can't seem to find who made one capacitor. The logo is a triangle with a hollowed center and I didn't see anything on http://capacitor.web.fc2.com/ after looking a few times.
    The markings that seem like company brandings are: "CE ST" on the bigger caps and "ST" on the smaller ones. Looking for "ST" capacitors head lead me on a dead end.
    Here's a recreation of the logo:
    Here's a couple pictures:
    And for the hell of it: The entire inside.
    • 31170
    Re: Unknown Capacitor in Proton Receiver
    that looks like a mitsubishi logo i think.
    btw, it's not important.
    those caps are 85' temp so they are just general purpose crap.
    you can replace them with rubycon YXA for example.
    • Compgeke
      • Feb 2014
      • 524
      Oh, I know they don't need replaced I've just never run across them before and just curious to know who actually made the things.
      The logo isn't quite the Mitsubishi one as that would be a triangle with 3 smaller triangles cut out with their points meeting at the center.
        • 31170
        o.k. i was close - it's matsushita ( a division of panasonic)
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • Teban1306
          [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
          by Teban1306
          Hello everyone!
          I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
          System Information:
          • Model: Lenovo ThinkPad T14 Gen 1
          • Machine Type: 20S1S4E600 (Intel i7 variant)
          • Current BIOS: N2XET42W (1.33) - Latest version
          • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
          What I'm trying to achieve:
          Replace the default "LENOVO" boot logo with a custom image during POST.
          🔧 What I've tried:
          09-14-2025, 11:49 AM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
