Noob capacitor question
  • clearchris
    • Dec 2013
    • 687
    What are the black rectangular caps? Are they electrolytics? Ceramics?
    I have a cisco 2600 series router that is acting flaky during high temps, so I suspect capacitors. There are 4 electrolytics, and a whole mess of the black type.
  • mariushm
    • May 2011
    • 3799
    Re: Noob capacitor question
    They're either Tantalum or polymer. Most likely with polymer, because plain tantalum are usually those yellow capacitors.
    See for example : http://industrial.panasonic.com/ww/p...AAA8000_e.html
    "POSCAP" is a solid electrolytic chip capacitor. The Anode is sintered Tantalum and the Cathode is a highly conductive polymer formed on SANYO Original method.
    "POSCAP" has a Lowest E.S.R. (Equivalent Series Resistance) level and excellent performance for high frequency though low profile and high capacitance.
    In addition, it has high reliability and high heatresistance.
    Therefore, "POSCAP" is an ideal chip capacitor especially for digital, high frequency devices.
    • clearchris
      • Dec 2013
      • 687
      Yeah, there are some yellow tantalum caps on the board, so they are likely polymer.
      So could there be a design reason why one wouldn't want a polymer cap (there are 4 electrolytic 330uf 16v)? They used plenty elsewhere on the board.
      • MORETTIGIAN
        Capacitor detached from PCB – RTX 2070 Super Founders Edition
        by MORETTIGIAN
        Title:
        Description:
        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
        I did not notice it detaching, so I am unsure of its original location on the PCB.
        Procedure performed:
        - Removed backplate
        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
        - Reapplied thermal compound
        - Reassembled card
        Observed behavior after reassembly:
        - GPU powers on and operates normally under...
        09-18-2025, 12:14 PM
      • Prolog
        RTX 3080 FE Identifying capacitor
        by Prolog
        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
        I hope these photos make it clear which component I am referring to:
        (yes, the soldering is a bit botched from removing the blown one, I know)
        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
        12-01-2024, 08:27 PM
      • martyb
        capacitor value too high
        by martyb
        so when 1000 uf caps red at 1150 uf does this mean capacitor should not be used and is this signs of a deteriorating capacitor or has it simply been made that way
        02-24-2023, 11:10 PM
      • chth96
        How can I test non-polarized capacitor?
        by chth96
        I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
        I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
        And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
        I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
        06-02-2024, 07:31 PM
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
