Hitachi capacitors
  • zuhr14
    • Dec 2013
    • 23
    • Antarktis
    Hitachi capacitors
    where I can buy Hitachi capacitors? (large for PSU or any other)
    Farnell,TME,DIGIKEY,DISTRELEC.. - no Hitachi capacitors found.
  • c_hegge
    • Sep 2009
    • 5219
    Re: Hitachi capacitors
    You can't AFAIK. Just go with an alternative from Rubycon, NCC, Nichicon or Panasonic.
    • zuhr14
      • Dec 2013
      • 23
      • Antarktis
      snap-in:
      HITACHI HP3 400V,390uF,85° (25x45),10MM pitch,4000H,R.C.:2360.
      (HP32G391MCYS6WPEC)
      25,4x45 = max. size (no free available space)
      100% alternative not exist (shit caps excluded from search) :
      I found only two applicable alternative:
      RUBYCON USH 400V,470uF,85° (25x45),10MM pitch,2000H,R.C.:2390.
      (400USH470SN25X45)
      and
      CHEMICON SMR 400V,390uF,85° (25,4x40),10MM pitch,2000H,R.C.:2400
      (ESMR401VSN391MQ40S)
      but these alternatives is unfortunately unobtainable.
      Current no alternative for this HP3
      • mariushm
        • May 2011
        • 3799
        Seasonic buys a ton of them and I think they may have some contract or preferential treatment deal where they have priority in purchasing them.
        They may also sell to a lot of big companies and therefore not be interested in selling low volumes at distributors like Digikey.
        • dragon3x
          by dragon3x
          power on.
          Here are some examples :
          switching supply area).
          than 6.3 V.)
          03-21-2025, 02:46 PM
        • competition
          Replacing capacitors in Evga PSU
          by competition
          I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
          11-14-2025, 11:12 AM
        • slybunda
          AA and AAA battery charger capacitors?
          by slybunda
          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
          it has inside:
          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
          2 x 470uf 16v LZ105c branded as G.Luxon
          not heard of these brands are they any good?
          iv attached photos of the charger and the board inside for an idea on the type of...
          12-24-2023, 04:41 AM
        • quickname
          Cyberpower 1500AVR UPS repair
          by quickname
          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
          I decided to verify that the batteries were...
          11-12-2023, 09:57 AM
          After all of...
          07-13-2024, 08:14 PM
