10U_0805_25V6K capacitor value
  • rictechie
    • Jul 2024
    • 17
    • Philippines
    Sorry I'm new in reading schematics can someone decode this for me Click image for larger version
    • 31289
    just a guess,
    10uF
    25v
    0805 size
    • jinu_j
      • Feb 2016
      • 90
      • India
      My guess is 10U_0805_25V6K would stand for
      Capacitance value - 10uF
      Size of the SMD capacitor - 0805
      Voltage Rating - 25V
      Thermal Rating Code - 6 - This corresponds to 105 Degrees
      Tolerance value Code - K - This corresponds to 10%
      • rictechie
        • Jul 2024
        • 17
        • Philippines
        can I use 50v instead of 25v?
        • jinu_j
          • Feb 2016
          • 90
          • India
          Generally should not make a difference.
          • rictechie
            • Jul 2024
            • 17
            • Philippines
            I tried finding thermal rating code of 6 but can't find only 5
            • Harjit
              • Jul 2025
              According to Google AI (2025) the thermal rating of 6 typically refers to the range +10c to +85c though when I repeated the query with different wording it said that some capacitor id’s that have 6 to indicate max 105c degrees.
              • MORETTIGIAN
                by MORETTIGIAN
                Title:
                Description:
                Procedure performed:
                - Removed backplate
                - Reapplied thermal compound
                - Reassembled card
                09-18-2025, 12:14 PM
              • Prolog
                by Prolog
                12-01-2024, 08:27 PM
              • Agent24
                Dick Smith Q-1760 linear power supply filter capacitor question
                by Agent24
                I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                It has at least one problem.
                The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                I have already ordered a replacement potentiometer, so that's not an issue.
                Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                All are CapXon...
                10-21-2025, 05:39 PM
              • chth96
                by chth96
                12-22-2023, 04:34 AM
              • chth96
                by chth96
                06-02-2024, 07:31 PM
