How near the rated spec do they nned to be?
  • bubo
    • Aug 2004
    I've found that RS componets in the UK do most of the caps I want but the 1500uF seems to be non existant in this country. How critical is it for the cap to be exactly this value? Would a 1200uF or a 2200uF be acceptable in its place? The m/b is an epox 8rda+.
    I've checked with digikey and they say they will supply low quantites but I'm guessing once post and packing is added it will work out rather expensive so a local solution is preferable.
    BTW, you might like to have a look at my site
    http://homepage.ntlworld.com/bubo/
    It shows infra red thermal images I took of my motherboard. The bad caps thing may explain why some of the mosfets are hotter than others.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Digikey is expensive to begin with... On small quantities and overseas, bend over!
    It's fine to substitute 2200uF caps in place of 1500uF caps. I wouldn't go down though. I would avoid using 1200uF caps if at all possible. They would probably be OK, since 1200uF is within the tolerance of 1500, but if I had to substitute, it's better to go up, not down.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Perry Babin
      Operating caps well below rated voltage
      by Perry Babin
      I think this has been answered but I couldn't find the thread.
      Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
      So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
      If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
      Or would it require reforming?
      05-23-2024, 05:43 PM
    • Phil289
      Audio rated caps - is it ok to use ‘audio’ rated caps on a non audio device
      by Phil289
      Hi
      Just a quick question - is it ok to use ‘audio' rated caps on a non audio device.
      Is there any reasons why they shouldn't be used?
      I'm just trying to find some good quality caps on ebay for a small repair and I've noticed there are alot of audo rated caps in the size i need but not so many non audio rated.
      If I can't find any Panasonic what would be any other good makes to consider?
      Thanks 🙂
      09-25-2022, 03:02 PM
    • UserXP
      Transformer producing higher voltage than rated
      by UserXP
      Hello, people.
      i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
      So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
      09-02-2025, 12:42 AM
    • kotel studios
      Compaq PDP-124P - loud screeching when running
      by kotel studios
      Recently I got my compaq PDP-124P to "work" and it now screeches loudly when running (you can hear it from 60cm away!).
      There's nothing shorted on it, caps were already checked and replaced when they were close to being above 20% of rated spec, apart from the primaries. Fan isn't the issue too.
      I didn't have time to measure the voltage rails (beside 12V, that one had 11.7V) due to the unexpected sound.
      Load was only an single sacrificial board w/o CPU power since these PSU's don't work without mainboards.
      Any ideas what could be...
      03-25-2025, 11:58 AM
    • slerner
      Lesser of 3 evils?
      by slerner
      Hi, my project is nearly on the right track https://www.badcaps.net/forum/showthread.php?t=115083 However, there's one last electrolytic cap that I need to replace and it's just not available, even at higher voltage. So, this question is a bit more general & maybe off-topic from my previous thread.
      I'm recapping a powered speaker that contains a mains transformer & all e-caps are 105c-rated general-purpose radial cans. The one I can't match is 12000uF 50V 10mm-spaced snap-in, 30mm diameter, ±20% tolerance. And here are my options:
      A) iffy quality: I've already bought some...
      02-05-2023, 12:21 AM
