Interesting capacitor testing done
Ryzen 3600x
16GB Patriot 3600MHz
MSI B450 Gaming Plus
MSI Air Boost Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
MG Chem .8mm 63/37 RA 2.2%Tags: None
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by genuineguyHello Experts
Need help with my experiment to test a Capacitor from microwave oven
Its a High voltage capacitor. 1mfd, 2100V AC.
A DMM test across its terminals show infinite/open resistance.
The capacitor has a 10Mohms shunt resistor internally.
1. Connected 100w bulb in series to the capacitor. AC supply 230v connected. The bulb did not light up. This proves the capacitor is NOT shorted
2. Connected capacitor in series with a diode and 10ohm, 10W resistor. Connected AC supply 230v. I was hoping DC voltage reading...-
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by sam_sam_samI just bought this device that came in the mail today I put a set of 4 brand new 21700 high current battery on the charger
The charger has four individual temperature sensors for each battery cell
The bar graph for each individual battery cell is very primitive but will give you a good idea of how each battery cell is preforming and I find something odd I put on the individual battery testing machine that gives more details of the charging/discharging curves but it will be quicker to just charge and discharge battery cells that do not have any issues
Or test... -
by Agent24I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
It has at least one problem.
The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
I have already ordered a replacement potentiometer, so that's not an issue.
Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
All are CapXon... - Loading...
