I have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps that as as close to the original specs as possible, but exact replacement don't seem to be available to order anywhere. I can match the capacitance and voltage but the ripple and impedence are more difficult, sometime I can match the ripple, but often I can only get kinda close, sometimes I can't even get close with what is available. The replacement guide says "the ripple current must be equal to or higher than the original parts".
Ripple seems to be the main thing I can differentiate on here, so if I can't find an exact match how far is it OK to deviate? Is a lot higher better than a little lower? I'm not sure what the interplay is between ripple, impedence, and the HDMI video signal.
