Ceramic cap brand ID?
  • TECHMECH
    • 21
    Does anyone recognize the manufacturer logo on this capacitor? [M]
  • Admin
    • Oct 2003
    • 5334
    I think it's the old Matsushita (became Panasonic) logo
    • TECHMECH
      • 21
      Thank you! I think you are correct. I see some Panasonic capacitors on google with this marking.
      • redwire
        • Dec 2010
        • 3910
        It's really thin for its 15kV rating?
        Mouser and Digi-Key have nothing for stock on HV ceramic caps.
        The cheap chinese HV caps are pretty thick but have a big voltage coefficient, so their capacitance value is pretty low at voltage.
        • Verlengsnoer
          Bios splash/logo change
          by Verlengsnoer
          at firs, i hope this is the right place to post my question.
          Im looking for a tool to change the bios logo.
          everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
          i know that HP has a build in option to change the splash logo.
          but i want to change the manufacturer logo to an own logo.
          I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
          10-28-2022, 09:52 AM
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • Stanley1843
          BEST 505 Vs Mechanic Brand Reballing Balls with Lead
          by Stanley1843
          has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
          06-22-2024, 11:06 AM
          Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
          by momaka
          This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
          Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
          Macron Power Technology Co. LTD.
          Let’s look at the PSU itself.
          The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
          06-02-2021, 10:05 PM
        • chth96
          by chth96
          03-09-2024, 10:03 PM
