Hello Everyone,
I'm working on an Akai LCT3285TA, and have put together a shopping list of replacement caps. Was wondering if someone more knowledgeable could check my choices of replacements to see if I'm correct.
ELXZ160ELL221MF15D - 220uF 16v 400mA ripple .18ohm Impedance 105c
(found above recommended in another post here)
ESMG350ELL222ML25S - 2200uF 35v 1670mA ripple .16ohm Impedance 85c
EKY-160ELL102MK15S - 1000uF 16v 1400mA ripple .18ohm Impedance 105c
35YXJ470MCA10X16 - 470uF 35v 1210mA ripple .13ohm Impedance 105c
35YXJ1000M12.5X20 - 1000uF 35v 1900mA ripple .041ohm Impedance 105c
In each case, I've tried to find replacements with equal or higher ripple, and equal or lower impedance, as recommended in several posts. Thanks in advance for your help.
