Identify some caps
  • gunnish
    • Oct 2013
    • 33
    • Sweden
    Identify some caps
    Need data for the following caps:
    Panasonic FJ: seems like no data sheet is available EDIT: ok fixed
    Chemi-con KZG: 6,3 V 820 uF 8x24 mm can't find one in that series with that size
    Chemi-con OS-CON: what, don't sanyo do theses? Anyway, I can't find a datasheet. 10x11 mm
    Fujitsu: thought it was FJ but i can't find a 2.5 V one there. 8x8 mm
    Turquoise test on aluminum one: no idea, most likely polymer 8x12 mm
    Fujitsu: I don't know the series 8x12 mm
    Thank you for any help.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Identify some caps
    Panasonic FJ datasheet located here hosted by one of our members: https://cdn.badcaps-static.com/pdfs/...598d4af80c.pdf
    I've noticed that all of the KZG datasheets are pretty old, or that was a custom sized cap. I'd just replace it with a 1000uF 6.3V cap to be safe
    That yellow Fujitsu cap should be fine, were you planning on replacing it?
    That OS-CON may just be a re-sleeved Sanyo
    That blue polymer is UCC PS series https://cdn.badcaps-static.com/pdfs/...0a13cd593c.pdf
    That red Fujitsu poly is probably RE series
    • mariushm
      • May 2011
      • 3799
      1. Panasonic FJ , datasheet here
      2. UCC KZG , datasheet here but you're right, weird to be 24mm tall for such low capacitance/voltage
      3. yeah, ucc has or had an OS-CON brand at some point... see the datasheets in this folder, one of those may be it.
      4. this is fujitsu before it was bought by nichicon, see this folder
      5. united chemi con (from logo and color), polymer, ps something series (they have psa, pswhatever)
      6. fujitsu fpcap around 2006-2007 / probably before it was bought and became nichicon fpcap, most likely re series something, r5 for example is here
      maaan... i have to sort out the collection of datasheets
      • gunnish
        • Oct 2013
        • 33
        • Sweden
        No I am not replacing any of these, I just want to know the specs. I like to look at electronics and see how good the design and parts choice is.
        • mariushm
          • May 2011
          • 3799
          United Chemi Con makes great quality capacitors but they screwed up with KZG series, it's actually quite a problematic one, a large percent go bad after a few years.
          The people here consider it bad, replace on sight, and UCC themselves have discontinued it.
          • gunnish
            • Oct 2013
            • 33
            • Sweden
            Is this Rubycon fake? IT seems like the bung would be made of something like fr2. never seen any bung like it. It's 18x21 mm.
            The other cap 10x20 mm. I'm not sure what the 'I' means and what brand/model it is.
            • mariushm
              • May 2011
              • 3799
              It would help if you'd post pictures.
              Yes, some large capacitors can use a sort of pcb like material at the bottom.
              I makes me think of Illinois Capacitors but without pictures I can't tell.
              • gunnish
                • Oct 2013
                • 33
                • Sweden
                Sorry, I meant to upload them but apparently just pressing the upload button is not enough.
                • mariushm
                  • May 2011
                  • 3799
                  In the last picture, that's not an I, that's just how Nichicon likes to tell you that side is the NEGATIVE of the capacitor, on some capacitors series of capacitors. The top is cut (or I should say the metal is slightly weakened) in the form of a + as a vent release mechanism (to let gasses get out if needed instead of blowing up from pressure)
                  The circle bent to one side is the logo for Nichicon. HD tells you the series of capacitors so you can get the specs from datasheet.
                  As for Rubycon capacitor, yes, that type of material was common in the past. That's an old series of capacitors, rated only for 85c and generic, nothing special about it (well, nowadays, compared to newer series of capacitors)
                  • Behemot
                    • 4845
                    • CZ
                    When? I still see them, with manufacturing dates of quite long after it was very well known what PoS it is.
                    mariushm: is this non-sleeved version catalogized or custom? It looks like polymer but in fact is ordinary HD, I have also seen other series in this package. I know some manufacturers make one model line in multiple packages but not sure with Nichicon.
                    Also these does not seem to be of much good quality. It seems those SMD caps in the ViewSonic VP211b I have been troubleshooting are Nichicon. Most of the small ones were bad but even after replacing most of them with incredible ESR, the display didn't come to life.
                      Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook U Specification for Upgrade or Repair
                      This specification for the Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7511 boardview and LIFEBOOK U7511 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-07-2024, 03:40 AM
                      Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook U Specification for Upgrade or Repair
                      This specification for the Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7411 boardview and LIFEBOOK U7411 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      Fujitsu LIFEBOOK LIFEBOOK U9311 Notebook U Specification for Upgrade or Repair
                      This specification for the Fujitsu LIFEBOOK LIFEBOOK U9311 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U9311 boardview and LIFEBOOK U9311 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-07-2024, 03:10 AM
