Capacitor SMD identify
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    In Sony Vaio PCG-7144M notebook is only one elyte capacitor - a small SMD cap that is d6.3 x 8 and looks like this - black print:
    On the cap is this:
    100
    EFK.
    8R6
    The NTB is from 2008 and it looks like Panny FK cap:
    http://s24.postimg.org/7gfwguzqd/Pan...0u_F_6_3_V.jpg
    ...since the "j" is the voltage and in this case 6.3V, while E in the voltage table:
    ...looks like 25V to me.
    The dot is mark about lead free product (I did not made it up).
    And a 100uF 25V Panny FK do have the d6.3 x 7,7mm (I rounded the 8mm to something like that) dimensions also.
    Therefore (except the unknown lot number) I would be inclined to believe that I got it right, but that of course awaits some approval
    That is, because I do consider Panny caps as good ones and the NTB behawe like it have all the bad caps inside: https://www.badcaps.net/forum/showthread.php?p=373108
    And that lead to my disbelief about what this is... not to mention that the NTB power cord claims to be 19,5V DC, witch corelate well with the 25V capacitance...
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
  • MORETTIGIAN
    by MORETTIGIAN
    Title:
    Description:
    Procedure performed:
    - Removed backplate
    - Reapplied thermal compound
    - Reassembled card
    09-18-2025, 12:14 PM
  • BlackBurn
    Help to identify a laptop mainboard SMD capacitor LA-9982P
    by BlackBurn
    I have an Dell Inspiron 15 3537 laptop mainboard (LA-9982P Rev. 3.0 (A02)) with a blown SMD capacitor as shown in the attached images. However, there is no printed specifications near the capacitor or a codename for the capacitor to identify the specification of the capacitor to replace it. I wonder how to identify the capacitor since the mainboard schematics are also useless as the capacitors are not named on the board. Any help would be highly appreciated.
    Thank You. Stay Safe.
    Chamara...
    11-27-2020, 08:30 AM
  • chth96
    by chth96
    12-22-2023, 04:34 AM
  • chth96
    by chth96
    06-02-2024, 07:31 PM
  • chth96
    Is it no harm to replace with capacitor without ripple current rating?
    by chth96
    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
    Rubycon YK DataSheet (b...
    04-19-2024, 05:19 AM
